Sleeve hitch
3 replies to this topic
#1 Swiftyd2014 OFFLINE
Swiftyd2014
  • 2 Thanks
  • 6 posts
Posted August 24, 2017 - 02:02 PM
On the sleeve hitches the rod that hooks to the hydraulics is there different lengths I went to hook mine up last night and it was way short or does another rod go into the slide part and hook in
#2 boyscout862 ONLINE
  • 12,577 Thanks
  • 9,053 posts
Posted August 24, 2017 - 04:41 PM
Check the manuals and post some pics. Good Luck, Rick
#3 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted August 24, 2017 - 05:39 PM
Again what tractor what year.Some older ones 2ft. overall length rod.
#4 KC9KAS ONLINE
KC9KAS
  • 5,331 Thanks
  • 4,674 posts
Posted September 12, 2017 - 06:37 PM
Check this out.
The 2 1/4" X 2 1/4"  "right angle" bracket needs to welded on the bottom side of the flat steel piece. The plan shows it welded to the top, and I think that is wrong.
Attached File  Gil 33096 Sleeve Hitch.pdf   40.53KB   33 downloads
  • Alltractoredup said thank you
