Wheel Weight Theory
32 replies to this topic
#31 4getgto OFFLINE
4getgto
  • 33 Thanks
  • 39 posts
Posted January 07, 2018 - 01:06 PM
My setup, 100lbs wheel weights + 250lbs suitcase weights in box.
I bet that gets around good. Do you use chains too?
Edited by 4getgto, January 07, 2018 - 01:07 PM.
#32 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted January 07, 2018 - 01:25 PM
Some times I need chains so this yr I put a set on.
#33 olcowhand ONLINE
  • 41,216 Thanks
  • 31,437 posts
Posted January 07, 2018 - 07:14 PM
I would fill the back tires with washer fluid and be done with it, I use loaded tires to mow and it doesn't hurt anything.
I do the same.  On steeper mow areas, the extra traction prevents wheel slip and subsequent burning, or digging up the grass.  On sidling mowing, the fluid ballast also gives a lot more stability.
  • MNGB said thank you
