Wheel Weight Theory
32 replies to this topic
#16 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted August 21, 2017 - 10:21 PM
 Has anyone really had axle wear issues?
Axle tubes on my old sears SS15 wore pretty bad. It had a huge chunk of concrete attached to the 3 point hitch when I got it. Must of weighed close to 300lbs but I didn't weigh it.
Axle seals were leaking bad so I replaced the seals but it didn't help much. And the differential was really noisy especially in reverse. Had to swap out the rear end.
  • LilysDad and Sawdust have said thanks
#17 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted August 22, 2017 - 07:16 AM
I would fill the back tires with washer fluid and be done with it, I use loaded tires to mow and it doesn't hurt anything.
  • MH81, LilysDad and Sawdust have said thanks
#18 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted August 22, 2017 - 07:44 AM
Where should I go to learn how to do that?
#19 MH81 OFFLINE
Posted August 22, 2017 - 11:14 AM
Do you happen to have an old pump sprayer for herbicides? If so, you can clean it out really really well and use that
#20 MNGB ONLINE
MNGB
  • 2,138 Thanks
  • 1,417 posts
Posted August 22, 2017 - 12:11 PM
Hi Lilly, ballasting the tires is a lot easier then most of us think at first I was one that found out its not hard once you get started, I've done three of my Power Kings, you need a couple of tools simple to get first is a small pump the ones that you chuck up in a 1/4" drill or so the second is an adapter to get the fluid into the tire, I'll attach a couple of links so you can see, I have the adapter linked it works good only thing it the air relief valve really doesn't I found it much simpler to remove the hose from the drill let the air escape and reattach the hose.To start let all the air out of the tire I set then up right with the valve stem up and start pumping in the fluid
https://www.walmart....8&wl13=&veh=sem
http://www.ebay.com/...119.m1438.l2649
#21 HowardsMF155 ONLINE
  • 2,861 Thanks
  • 2,988 posts
Posted August 22, 2017 - 08:10 PM
As with so many things in life, there is more than one way to do it.  Personally, I like using an inexpensive ($10) garden sprayer.  Here is my link and some pictures:
http://gardentractor...es/#entry212710
Super easy, you can keep setting it up, pumping in fluid while you putter around doing other things and refill and repeat.
  • Sawdust said thank you
#22 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted August 22, 2017 - 08:19 PM
How much fluid does it take to fill a 23-10.50-12 and how heavy will it be?
#23 dropped82 ONLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted August 22, 2017 - 09:06 PM
I put 5 gallons per tire. Roughly 8 lbs per gallon. I also use a weed sprayer for filling mine. Remove the wand from the hose and slip the hose on the valve stem with core removed.
  • Alc, LilysDad, Sawdust and 1 other said thanks
#24 chieffan ONLINE
  • 10,194 Thanks
  • 6,657 posts
Posted August 23, 2017 - 07:58 AM
I have filled about 4 sets of my Bolens rear tires with RV antifreeze.  Break the bead free from the rim in one area only.  A screw driver will hold the tire away from the rim enough to simply pour the fluid in right out of the jug. Little air to set the bead and mount the tire back on the tractor.  No other items needed and much faster.
  • dropped82, LilysDad and Sawdust have said thanks
#25 Sawdust ONLINE
Sawdust
  • 5,677 Thanks
  • 3,380 posts
Posted August 23, 2017 - 10:02 AM
Im a strong believer in keeping the weight in the wheels or tires. Counter weight if needed keep it minimal. I think loaded tires has it's advantages year round.
  • dropped82, LilysDad and MNGB have said thanks
#26 TAHOE ONLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted August 23, 2017 - 11:19 AM
I used a small Crapsman LT with a snowblower for years, little 18 or 20' turf tires with chains, no extra weights. It did fine overall, only lost steering when blower was on the ground.
On my Sears 16/6, I run washer fluid loaded rears and plastic 55# wheel weights all years round, tires are Deestones 23x10.50. Does pretty well, but I think it would do better if I have true 10.50 wide tires, mine only measure 9.0.
I broke the bead, set tire up on something so it was at a slight angle, used a funnel and poured it in. I got roughly 6 gals per tire.
#27 MH81 OFFLINE
Posted August 23, 2017 - 12:56 PM
FYI: Bead break vs sprayer.
Biggest difference would be tubed or not.
  • KennyP, Sawdust and MNGB have said thanks
#28 dodge trucker ONLINE
dodge trucker
  • 2,453 Thanks
  • 3,135 posts
Posted December 31, 2017 - 09:16 PM
I got 7-1/2 gallons in each of my rear tires on my Ariens, 23x10.50-12s wasn't enough. Got 3 feet out of the garage, it kicked a chain and I sat and spun, this with the plow set ~1/2 to 3/4" high with the skids on the ground so I don't take the gravel with the snow. Got 2 sets of IH cast iron weights that I was hoping to save for the other tractor that is getting the blower installed.
I saw a cool looking setup on one of the Wisconsin CL's basically an x with a steel bar welded to it, bolt the x to the rim and add barbell weights to your desires. I might have to make a couple of those doohickeys. I can get barbell weights cheap enough from the auction or garage sales.
#29 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted December 31, 2017 - 09:38 PM
That's what I was talking about in the first place. If you use a piece of the bar bell bar welded to the X, then you can use the quick spin on nut to install weights.
  • DH1 and dodge trucker have said thanks
#30 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted December 31, 2017 - 09:43 PM
My setup, 100lbs wheel weights + 250lbs suitcase weights in box.
  • shorty and LilysDad have said thanks
