Vanguard questions
5 replies to this topic
#1 glgrumpy OFFLINE
  • 8,849 Thanks
  • 8,036 posts
Posted August 20, 2017 - 09:12 PM
18hp Vanguard twin. Missing one head, not sure which side. I put the one on block, the bolts fit both sides. Only thing seems diff is the inlet and outlet I guess. SO, thinking mine is right side head, but don't see any numbers on it. This is facing side with cover over flywheel with intake facing that way. I'm hoping 16 and 20 are same, still haven't found out yet. I see more 16 than any other size.
Was wondering what those two beads in the cam lobes are for? That just a bump up at start for compression release? They seem to be for only one side.
Edited by glgrumpy, August 20, 2017 - 09:13 PM.
  • Mark 149 J. said thank you
#2 stiemmy OFFLINE
stiemmy
  • 2,538 Thanks
  • 1,830 posts
Posted August 21, 2017 - 03:33 AM
Short answer, yes, the weight on the cam gear is the giveaway.
Edited by stiemmy, August 21, 2017 - 03:37 AM.
#3 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,520 Thanks
  • 6,166 posts
Posted August 21, 2017 - 05:55 AM
That is the weirdest ACR setup I've ever seen..   :say_what:
#4 glgrumpy OFFLINE
  • 8,849 Thanks
  • 8,036 posts
Posted August 23, 2017 - 09:27 PM
Well, at Portland today and looking around for other items when see a Vertical Vanguard on ground kinda ruffish.  I'm thinking many parts are same as horizontal, so buy it for $40.  Go down same aisle a bit, see a Zero-turn with some apart Vanguard on it, but horizontal. AND, behind that on trailer another horizontal all apart in a box. It had one head loose, looked and that side no turn piston. $20 for that one, $45 for one setting on the mower, seems better.  Wasn't having luck finding any engines, then find three down one row today! Sheesh!  So now have many to play with. Those three are a 16hp models, so will be seeing what is same as the 18 I have. Think might get two engines out of the four I will have now. Happy Wrenching!
  • KennyP, Cvans and Mark 149 J. have said thanks
#5 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted August 28, 2017 - 10:23 PM
Great score!
#6 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,520 Thanks
  • 6,166 posts
Posted August 28, 2017 - 10:28 PM
BTW the head you are missing is #2..  #1 is closer to the Flywheel..
