New farmette 45 need some help
7 replies to this topic
#1 whtractors24 OFFLINE
whtractors24
  • 22 Thanks
  • 12 posts
Posted August 20, 2017 - 01:27 PM
Nice orignal farmette I just cleaned up I just recently got . Few questions both drive belt sizes ? Also did they make a mode 70 with a kohler really getting into it and like to find one with a kohler . Also a parts diagram with sizes of possible . Thanks. In advance .
#2 whtractors24 OFFLINE
whtractors24
  • 22 Thanks
  • 12 posts
Posted August 20, 2017 - 01:28 PM
Pic
  • Alc, jimmy G and Mark 149 J. have said thanks
#3 jimmy G ONLINE
jimmy G
  • 1,197 Thanks
  • 779 posts
Posted August 20, 2017 - 06:20 PM
Nice tractor,there is a manual section here that might have what you need,I'm guessing that's a shifter under the steering wheel, very cool
#4 jabelman OFFLINE
jabelman
  • 2,231 Thanks
  • 1,596 posts
Posted August 20, 2017 - 07:22 PM
I had a chance to buy one of those, wish I did. only had room for 1 tractor in the back of the truck, I bought the gemco big boy he had instead
#5 glgrumpy ONLINE
  • 8,616 Thanks
  • 7,923 posts
Posted August 20, 2017 - 09:02 PM
That's different!  Little diff way to shift it looks like!  Bet you'll be measuring belts with ropes around pulleys on that one, not much info I"m betting.
#6 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted August 21, 2017 - 06:31 AM
:wave: Welcome to the forum. We have some manuals here.
#7 whtractors24 OFFLINE
whtractors24
  • 22 Thanks
  • 12 posts
Posted August 22, 2017 - 10:18 PM
Got it all corrected and greased . Notice drive pulleys get pretty hot after 5 mins of driving . Pulled them all apart and bearing and all is in good shape and greased wellcwhst can it be?
#8 jimmy G ONLINE
jimmy G
  • 1,197 Thanks
  • 779 posts
Posted August 23, 2017 - 01:31 PM
I'm thinking loose belt, a slipping belt will get hot quick, check belt tension engaged, make sure enough pressure is being applied( a weak spring, limited movement or belt a touch long),if engaging at top of pedal belt is loose, if engaging at 3/4 pedal not enough pressure, it is normal for pulleys to heat with use but with a light load (not working hard) this should take a lot longer than 5min.s
Edited by jimmy G, August 23, 2017 - 01:45 PM.
