JD 265 Repower
jd 265 john deere 265 jd 265 repower
73 replies to this topic
#61 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 12, 2017 - 06:10 AM
Sunday, I took the hood off and pulled the grille and headlights off it. Has a crack at the top left due to the top of the grille being pushed back in.
I glued the hood back together with the E-6000, it takes 3 days to reach maximum strength. I did put another piece inside to span the crack.
Yesterday, I started bending the grille back into shape and the paint was flaking off bad. No primer under it. So I scraped as much as I could off and used the Mapp Gas torch to get the rest off. Have a coat of Rust Reformer on it now. I have no JD Green, so the grille may be left black, we'll see. I'll get some pics today.
The headlights do work! Cleaned the dirt off the bulbs and made sure the connections weren't rusty.
  • Mark 149 J. said thank you
#62 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 12, 2017 - 09:41 AM
Here's the hood repair. I'll leave the clamp on until tomorrow morning.
This is what the grille looks like right now. May get a can of JD paint tomorrow.
I've been thinking about the PTO and I am going to try to use the Poulan setup. Just hope it doesn't put the PTO too low. Once it warms up a bit today, I'll see what transpires with that.
  • lrhredjb, TomLGT195 and Mark 149 J. have said thanks
#63 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted September 12, 2017 - 10:58 AM
The black grill looks good.  I say go with it!
#64 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 12, 2017 - 11:16 AM
That's just Rust Reformer. But I may temp it into the hood tomorrow and see what it looks like
I got out the Poulan drive pulley and PTO. Looks like that would put the PTO pulley at least 1" below where the original was. Don't think that would work.
#65 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 12, 2017 - 03:52 PM
Well. I looked things over and it dawned on me that the Poulan PTO was 3/4" shorter than the JD. That put things back into a workable situation. But I needed a 3/4" bushing between the PTO and drive pulley. Good old HF band saw came through with that issue. Then I needed to extend the pin the keep the PTO from turning with the crankshaft. Made up a piece for that.
Got the pin attached.
And the deck is back on! It mows again! Done tried it out!
Now for a charging system! Gotta find a flywheel!
  • TomLGT195 and Mark 149 J. have said thanks
#66 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 13, 2017 - 09:47 AM
Here's what it looks like with the black grille.
#67 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,332 posts
Posted September 13, 2017 - 10:27 PM
Looks good to me!  Give it a little attitude!
#68 TomLGT195 OFFLINE
TomLGT195
  • 3,826 Thanks
  • 2,813 posts
Posted September 14, 2017 - 04:19 PM
I agree , looks good that way.
#69 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 20, 2017 - 07:13 AM
Had a little time yesterday and changed the engine oil and filter. Put in 10W30 full synthetic as Kohler says this is suitable for this engine. It was some dirty oil. Hope to get a filter for the rear axle soon and change that out.
#70 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,332 posts
Posted September 20, 2017 - 09:21 AM
I would have thought they would have recommended a 30W oil and not 10W30.
#71 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 20, 2017 - 01:12 PM
They show a 30W, but the multi-weight is optional!
#72 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 21, 2017 - 05:30 PM
Changed out the hydro fluid today, but it's still nasty in there! Think I'll give it about 10 hours clock time and drop the fluid.
#73 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted September 21, 2017 - 06:15 PM
What does that call hydro for?
#74 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 22, 2017 - 05:09 AM
If I understand your question right, this is from the manual:
I PM'd Daniel (olcowhand) and he said I could use the 303 fluid in there. I have enough of it to change it out again.
  • Trav1s, TomLGT195 and Mark 149 J. have said thanks
Also tagged with one or more of these keywords: jd 265, john deere 265, jd 265 repower
