JD 265 Repower
jd 265 john deere 265 jd 265 repower
73 replies to this topic
#31 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted August 29, 2017 - 07:12 AM
Here's the tag for it. Looks like a 1989 tractor from what I have found. I do know the deck was replaced with a newer 48" unit.
#32 lrhredjb OFFLINE
lrhredjb
  • 697 Thanks
  • 569 posts
Posted August 29, 2017 - 09:36 AM
Enjoyed reading about your project. Coming along nicely.
#33 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted August 29, 2017 - 10:48 AM
Thanks! It's in slow mode right now, needing a few things to finish it. But it was fun to drive it!
  • TomLGT195 said thank you
#34 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted August 30, 2017 - 03:27 PM
I got it out and just drove it around. Forward speed is impressive! Still have a creep issue, hoping driving it will help that, but I have the TM for it now.
#35 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 01, 2017 - 04:33 AM
Well, I just bought the stator for this engine. <$18 to the door. Now to find a flywheel cheap. Been driving it around. Creep is getting better, it's mainly when using the brake. So an adjustment may fix it.
#36 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 01, 2017 - 04:36 PM
Here's the mower deck #'s:
M0048DB140004
#37 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 03, 2017 - 12:33 PM
I was bored this morning so I wired in the second hour meter. This one is for the engine as it came off that machine. About 487 hr's. on the clock. Pretty simple to do. Had to first make a bracket to hold it. Just wired it parallel to the original.
While I have these pics, a question about the stator/ regulator. Should I use the reg./rectifier on the engine or use the one for the 265? I can hook the stator wires into the JD harness, that connector is just below the hour meter. The JD rectifier has 6 wires on it, that's what feeds a lot of the existing wiring. I have a stator coming, still need a flywheel with magnets.
#38 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 03, 2017 - 01:06 PM
Since the F725 uses the same ignition switch, I borrowed it for this tractor. No more jumper wires!
#39 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 04, 2017 - 02:07 PM
Scooped up the deck with the FF20 and fork lift! It needed some cleaning.
Looks better and I put 15 squirts of grease into each spindle.
I'll pull the blades when I mount the deck and sharpen them a bit. Not too bad right now.
#40 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 04, 2017 - 02:08 PM
Still waiting on an answer to my question in post #37.
#41 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 04, 2017 - 02:48 PM
Guess I'll just 'wing it'!
#42 lrhredjb OFFLINE
lrhredjb
  • 697 Thanks
  • 569 posts
Posted September 04, 2017 - 04:06 PM
Thats a lot of grease in the spindles, too much will blow the seals out then shorten the bearing life. I usually put in two pumps.
#43 TomLGT195 OFFLINE
TomLGT195
  • 3,826 Thanks
  • 2,813 posts
Posted September 04, 2017 - 04:12 PM
Sorry not much of a wiring/electrical guy. Deck looks to be in decent shape.
#44 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 04, 2017 - 04:30 PM
They probably haven't been greased in the last 4 years!
#45 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 05, 2017 - 05:17 PM
Found some tubing that fits the exhaust, so I started working on the muffler. I started it and it is much quieter with this.
I'll plug off the original inlet and move the mount to a vertical position when the wind calms down for welding.
  • Trav1s and TomLGT195 have said thanks
Also tagged with one or more of these keywords: jd 265, john deere 265, jd 265 repower
