782
value
10 replies to this topic
#1 sodbuster10231 OFFLINE
sodbuster10231
  • 18 Thanks
  • 37 posts
Posted August 18, 2017 - 04:39 PM
are the 782's worth more than different models? is there something special about a 782?
#2 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,824 Thanks
  • 2,782 posts
Posted August 18, 2017 - 05:37 PM
hey welcome to gttalk!
 I myself like just about any old garden tractor.  A red Cub 782 is a good one, but the original 17 hp kohler motor that was in them had some problems
  • sodbuster10231 said thank you
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,322 Thanks
  • 9,788 posts
Posted August 18, 2017 - 06:02 PM
Special? Well, it's an IHC CC. It's an 82 series, that's a good thing. If the engine was replaced with a series II engine which has an oil pump and an external oil filter that's all good. It has a hydraulic lift. A 682 has a manual lift.
#4 sodbuster10231 OFFLINE
sodbuster10231
  • 18 Thanks
  • 37 posts
Posted August 18, 2017 - 06:35 PM
I found one,think he is a bit high on the price.
#5 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,824 Thanks
  • 2,782 posts
Posted August 18, 2017 - 11:18 PM
there is a 782 for sale in Pleasant Hill, MO. Looks like it is in good shape. It has a reasonable price on it too, but I would offer a little less than he is asking for it   https://kansascity.c...6245956408.html
Edited by Delmar, August 18, 2017 - 11:35 PM.
#6 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,824 Thanks
  • 2,782 posts
Posted August 18, 2017 - 11:29 PM
here is a really nice 982...   https://minneapolis....6254622973.html
#7 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted August 19, 2017 - 07:22 AM
The 782 is a desirable model in the Cub community. The original series 1 engines have issues but the series 2 solved those issues. It is possible to get a 782 that was made by IH or CCC since IH sold Cub Cadet to CCC in 1981 and those were the current model tractors at the time, the tractors are identical but the ones made by IH generally go for a little more.
  • jimbobbillyray and sodbuster10231 have said thanks
#8 sodbuster10231 OFFLINE
sodbuster10231
  • 18 Thanks
  • 37 posts
Posted August 19, 2017 - 09:09 AM
Minneapolis is a little to far.982 is sweet,really like to have that.I am on the have to fix it side,cannot give $4000 for a toy!
#9 sodbuster10231 OFFLINE
sodbuster10231
  • 18 Thanks
  • 37 posts
Posted August 20, 2017 - 06:33 PM
how can you tell if it is a ih tractor or ccc tractor?
#10 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted August 20, 2017 - 07:01 PM
If the tag on the side of the frame says International harvester then it's IH made, if it says Cub Cadet Corporation the it's CCC.
#11 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted August 20, 2017 - 09:55 PM
Also, a MTD built unit will not have IH badges on it. If the tag is gone, another way to tell is the rear end. IH and very early CCC units have a cast iron rear with aluminum axles tubes. Subsequent units had an all aluminum rear end.
One way for a 782 to be worth a whole lot more is to add a 'D' after the 782, and have the Kubota diesel in it.
Also tagged with one or more of these keywords: value
