I saw a B 207E Allis chalmers today,
8 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,740 Thanks
  • 4,516 posts
Posted August 15, 2017 - 08:46 PM
Sorry no pictures, but this guy is fixing it up and gunna use it as a trailer hauler. Not all back together yet. Paint colour is not right, but who would know. Has a decal kit coming for it. Rear end looks a lot like a MF 7 rear end. But not quite the same. What I can't figure out is,,, the engine has horizontal pulleys and the transmission has vertical pulleys. How dose it drive ? Remember, it's not all together so I can't see how it's driven or how a clutch works.
Any way, just something for discussion. Never seen one before.
Noel
Looks like this one,
#2 jimmy G OFFLINE
jimmy G
  • 1,308 Thanks
  • 831 posts
Posted August 15, 2017 - 10:01 PM
The belts are twisted, i got a GTV 18 and you should see twists in its drive belt, two vertical pulleys at 90 degree angle lol,(just want the engine out of it)
Edited by jimmy G, August 15, 2017 - 10:02 PM.
  • boyscout862 and propane1 have said thanks
#3 CRFarnsworth ONLINE
CRFarnsworth
  • 5,219 Thanks
  • 2,271 posts
Posted August 16, 2017 - 08:56 PM
Noel
I have one of those only with the flat hood.   pics tomorrow.
I have the mower deck for mine but it is missing the lift arm and brackets.       Rick
  • propane1 said thank you
#4 CRFarnsworth ONLINE
CRFarnsworth
  • 5,219 Thanks
  • 2,271 posts
Posted August 17, 2017 - 11:22 AM
Pics as promised.  The starter generator is almost as large as the engine.
  • Talntedmrgreen, GTpicker01, propane1 and 2 others have said thanks
#5 propane1 ONLINE
propane1
  • 9,740 Thanks
  • 4,516 posts
Posted August 17, 2017 - 02:33 PM
Looks great, and ya, the starter / generator is big. So no float in front axle , so where does it float to keep all wheels on ground. Front axle is welded to frame.
Noel
#6 jimmy G OFFLINE
jimmy G
  • 1,308 Thanks
  • 831 posts
Posted August 17, 2017 - 03:26 PM
The body twists right in front of the shifter, I have two to make one out of, mine are a little older and are called 717 sovereign. The oblong hole to the right of shifter is for hi-low and is achieved through a gear set on the right side drive wheel separate from trany, very unique
Edited by jimmy G, August 17, 2017 - 03:36 PM.
#7 Talntedmrgreen OFFLINE
  • 3,292 Thanks
  • 2,319 posts
Posted August 21, 2017 - 02:11 PM
I have a B-208 that I use regularly...same as a 207 but with an extra pony under the hood.  They are great little machines.  They use a peerless transmission, which is why it probably looks like what you have seen.  The Simplicity equivalents used a Simplicity transmission, but by 68 when these 207s came into production, the govn't had Allis building machines in their own building, with slight variations due to anti-trust laws (Allis owned Simplicity at the time).
The Simplicity 717 was a Broadmoor model.  The Sovereigns were the full size large frame garden tractors with horizontal shaft engine.
  • jimmy G said thank you
#8 jimmy G OFFLINE
jimmy G
  • 1,308 Thanks
  • 831 posts
Posted August 21, 2017 - 05:27 PM
[quote name="Talntedmrgreen" post="788479" timestamp="1503342711"
The Simplicity 717 was a Broadmoor model. The Sovereigns were the full size large frame garden tractors with horizontal shaft engine.[/quote] yep i called my broadmoor's sovereign's by accident, this site has no mercy for the elderly memory lol, still batting 50/50 on my post so at least I'm not losing ground (yet) not sure why I'm having quoteing problem's all of a sudden though
Edited by jimmy G, August 21, 2017 - 05:35 PM.
#9 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 744 Thanks
  • 617 posts
Posted April 16, 2018 - 08:10 AM
I just bought one of these over the weekend and am searching for info and not finding a whole lot. It runs, but I have to jump the switch because it has not key! haha
