Nice new addition!
13 replies to this topic
#1 MGP59DB OFFLINE
MGP59DB
  • 1,782 Thanks
  • 808 posts
Posted August 12, 2017 - 04:26 PM
I am always looking for something DB related to add into the stable !
Found this about 75 Miles away from me and had to go and see it , I made an offer and it was on the trailer home.
Just got it in the driveway !!
Now the reason I really went down there today (saw it on C/L just this morn 8AM)was because of a couple things that are not quite original to these machines. :D
Rusty' and I have been looking for the aftermarket fenders for awhile and this has them. Plus the hubcaps aren't stock I don't believe .
It is a 1963 725' 917-60629 model# , the motor is not original but a nice replacement '170402'.  . I am pleased with the thing .
It has the complete 3point hitch set-up . It has a weak spark , probably just needs to be cleaned on the points and flywheel , good compression . Been sitting a couple 3 years.
This will make a nice addition to my DBs . :thumbs:
  • jhn9840, Alc, KennyP and 13 others have said thanks
#2 MGP59DB OFFLINE
MGP59DB
  • 1,782 Thanks
  • 808 posts
Posted August 13, 2017 - 08:32 PM
Well... after some playing around with the points and wiring ,we found some flaws and corrected them . This is a good running and driving machine!!
Started the cleaning up of it .
  • KennyP, Zekkjacen and Leonard VanCamp have said thanks
#3 kjmweld OFFLINE
kjmweld
  • 627 Thanks
  • 396 posts
Posted August 13, 2017 - 10:04 PM
Looks like it's in very nice condition overall, good find.
  • Zekkjacen and MGP59DB have said thanks
#4 tiretrx OFFLINE
tiretrx
  • 2,273 Thanks
  • 1,227 posts
Posted August 14, 2017 - 08:11 AM
Nice find, congrats :thumbs:
  • MGP59DB said thank you
#5 MGP59DB OFFLINE
MGP59DB
  • 1,782 Thanks
  • 808 posts
Posted December 10, 2017 - 05:58 PM
Well , after playing around with this tractor ,fixing the motor so it runs good and getting the belts right this summer I decided to hook up my dozer blade and back blade on it for winter.
We had about 5" of snow over the weekend and I tried it out !!
Wow , now this is a great machine , it is fast and it has power to push.
Rusty was good and all , but I am very impressed with how this 7.25 works compared with the 5.75 .
A real bargain seeing as I mostly bought it for the fenders.  :D
  • KennyP, Leonard VanCamp and Mark 149 J. have said thanks
#6 KennyP ONLINE
  • 41,449 Thanks
  • 47,382 posts
Posted December 10, 2017 - 06:38 PM
What's it's name going to be? Pusher?
#7 MGP59DB OFFLINE
MGP59DB
  • 1,782 Thanks
  • 808 posts
Posted December 10, 2017 - 08:15 PM
I was thinking more like 'Speedy' .. it is pretty fast !  :smilewink:
The variable speed controller works like a champ.
Edited by MGP59DB, December 10, 2017 - 08:17 PM.
#8 MGP59DB OFFLINE
MGP59DB
  • 1,782 Thanks
  • 808 posts
Posted January 08, 2018 - 11:31 AM
I was just out doing some cleanup with this beast  :D
Took some pictures.
It was warming up and the snow is sticky and heavy , but this thing is a workhorse and was able to get the job done !
  • olcowhand, Alc, KennyP and 3 others have said thanks
#9 tiretrx OFFLINE
tiretrx
  • 2,273 Thanks
  • 1,227 posts
Posted January 08, 2018 - 11:36 AM
Ole girl still got legs! Looks part billy goat.
  • KennyP, Leonard VanCamp, MGP59DB and 1 other said thanks
#10 MGP59DB OFFLINE
MGP59DB
  • 1,782 Thanks
  • 808 posts
Posted February 09, 2018 - 09:45 PM
Well , after getting quite a bit of use this winter , the old goat started giving me some trouble . Found a screw missing from the bottom of the carb . gas is leaking all over , It looks like the whole fuel system need an overhaul . Oh well , I know it will be worth the trouble , So out came 'Rusty' to the rescue !!
A little starter juice , First pull , running like a Champ !
#11 MGP59DB OFFLINE
MGP59DB
  • 1,782 Thanks
  • 808 posts
Posted February 15, 2018 - 12:13 PM
OK - so I had some Carb problems , I found a new 'Carburator' It was attached to this Engine.
The guy said he put this on and it wouldn't run - start but not run.
Sooo, Since this Monkey motor is 8hp and all- I figured I could use a lot of parts from it for other things , same config as most B&S of this general size. It is a '72 8HP that was on a Rototiller.
So I takes a look at it and he botched up the install of the new Carb - He had the Gov. set-up jammed up so it wouldn't move and the throttle locked down so it couldn't move .
I offered him 2/3rds of his asking price and took it away.
It took me 23 minutes to get it fixed and running :D (My brother was timing me and I didn't know it. ) I said it would take 15.
That includes checking the Oil and adding gas .
Since the Motor on this tractor is not original anyway I am going to put this one on the (Blue Monkey) and give it a try.
#12 ACmowerguy OFFLINE
ACmowerguy
  • 459 Thanks
  • 387 posts
Posted February 21, 2018 - 11:07 PM
I'm digging those fenders!
#13 MGP59DB OFFLINE
MGP59DB
  • 1,782 Thanks
  • 808 posts
Posted February 22, 2018 - 07:14 AM
Thanks ! I was sure happy to find them .
So was 'Rusty"  :smilewink:
We came a long way .
Edited by MGP59DB, February 22, 2018 - 07:19 AM.
#14 MGP59DB OFFLINE
MGP59DB
  • 1,782 Thanks
  • 808 posts
Posted June 13, 2018 - 03:58 PM
The swap is done Ready To Go !!
