Engine replacement
4 replies to this topic
#1 Heinen86 OFFLINE
Heinen86
  • 44 Thanks
  • 42 posts
Posted August 12, 2017 - 08:36 AM
I have a 1220 with the tecumseh HH120....runs great no issues so far but if something ever happens is there a new compatible engine to replace it with?
  • blackjackjakexxix, Oldford and logmillingman have said thanks
#2 Bolens 1000 ONLINE
  • 15,433 Thanks
  • 18,286 posts
Posted August 12, 2017 - 08:48 AM
Simple, Replace it with another  HH120?   :)
#3 jabelman OFFLINE
jabelman
  • 2,250 Thanks
  • 1,612 posts
Posted August 12, 2017 - 10:10 AM
one thing I do for every tractor I restore I track down another engine to keep on hand. you never know when you might need it and some of these older engines are getting tougher to find
  • blackjackjakexxix, Oldford, logmillingman and 1 other said thanks
#4 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted August 12, 2017 - 11:10 AM
Sometimes it is easier to keep a good engine running, there are a lot of site sponsors with parts for old bolens if you go that route
  • blackjackjakexxix, logmillingman and Heinen86 have said thanks
#5 Cnc OFFLINE
Cnc
  • 85 Thanks
  • 57 posts
Posted August 12, 2017 - 11:44 AM
The HH120 was used in other applications including the Massy MF 12. I have owned a if 12 since almost new and rebuilt it once then the second time the engine was getting tired, I was lucky enough to find a brand new short block through a local dealer. It was an HH120 but had a couple of extra letters or #'s to the model #. I could try and find the paper work.
We ordered it from the dealers supplier not sure what the difference would be. Turned out exactly the same except the crank case did have a larger oil capacity by about a litre or so due to a slightly different shape at the base. All parts bolted right up and it bolted right in.
That was only about 8 years ago, so there may be the odd one still floating around out there.
