Fuel in crankcase
6 replies to this topic
#1 Gullpt OFFLINE
Gullpt
  • 1 Thanks
  • 2 posts
Posted August 12, 2017 - 04:50 AM
I have a Ford 120 with Kohler k301 and have been finding gas in the crankcase after the tractor has been sitting. I've been shutting off the petcock but apparently isn't holding. I never used to have to shut it off to begin with, hopefully someone here would reccomend a solution .thanks in advance!
#2 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted August 12, 2017 - 05:28 AM
:wave: Welcome to the forum! Sounds like the needle in the carb is not closing off. Could be the float is bad and full of fuel!
  • MH81 and boyscout862 have said thanks
#3 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted August 12, 2017 - 06:30 AM
Check the diaphragm on the fuel pump. If it is bad the fuel will pass through, and go into the crankcase.
  • limebuzz, MH81 and KennyP have said thanks
#4 chieffan ONLINE
  • 10,135 Thanks
  • 6,632 posts
Posted August 12, 2017 - 12:50 PM
In line fuel shut off.  Put them on everything that has an older carb on it, especially a fuel pump.
#5 Gullpt OFFLINE
Gullpt
  • 1 Thanks
  • 2 posts
Posted August 12, 2017 - 05:43 PM
Thanks all for the help, I pickedup an inline shutoff today. If the fuel pump diaphragm were leaking would the tractor still run? I ask because it runs like a top. Only time fuel is found in oil is after sitting for a week or so.
#6 jabelman OFFLINE
jabelman
  • 2,230 Thanks
  • 1,595 posts
Posted August 12, 2017 - 07:22 PM
exactly every tractor I own I added one too, nothing worse than losing a whole tank of fuel out the carb in the shed
#7 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted August 12, 2017 - 11:06 PM
It has to be the fuel pump. On a k series the intake valve is higher than the carb so it cant be a carb issue. The engine will still run ok with a bad pump but you need to install a new one, adding a fuel shut off is just a band aid.
  • MolonLabe said thank you
