grader blade
22 replies to this topic
#16 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted June 25, 2011 - 10:16 AM
My challenge is which one gets the blade: Ford, Sears, or Cub? Maybe I need to make three. I would like to have the ability to tilt side-to-side. I need to look at some of the 'parts' I have been collecting for this. I have some galvanized pipe that looks close to sliding inside of another piece. If it will, then I can make it tilt. Also, I want it to rotate so the 'spoil' can go out either side. Kind of like a road maintainer/grader. That can be accomplished, just which one gets it? Decisions, decisions.
The Ford has a pusher blade, the Sears has a rear blade, but the Cub has neither.
Give it to the Cub so you have an entire road crew. :D
#17 Rick Brumback OFFLINE
Rick Brumback
  • 19 Thanks
  • 124 posts
Posted June 25, 2011 - 08:33 PM
Nice Massey,great job on the blade also.
#18 MH81 OFFLINE
Posted June 25, 2011 - 11:50 PM
Here is a Sears Grader Blade manual that has tilt in it. This blade is for the Suburban tractors.
Sears Mid Mount Grader - Manuals - Garden Tractor Talk - Forums
  • tinner, Alc, wvbuzzmaster and 1 other said thanks
#19 mjodrey OFFLINE
Posted June 26, 2011 - 04:31 AM
that is an excellent job on the grader blade.
I like your idea for controlling the angle adjustment.
Ditto !
#20 KennyP ONLINE
  • 37,393 Thanks
  • 45,448 posts
Posted June 26, 2011 - 06:06 AM
Thanks for the manual. I followed a thread over at MTF where a guy built one of these. Came out pretty close to the one in the manual.
#21 jppr26 OFFLINE
jppr26
  • 1 Thanks
  • 21 posts
Posted August 22, 2011 - 10:18 PM
i have a front mount grader blade on my wards squire 12 works great, but if your pushing dirt with it to much will high center the tractor, but with those rear mounted ones like MF did i doubt you would have that problem, as much
#22 skyrydr2 OFFLINE
  • 3,869 Thanks
  • 3,401 posts
Posted August 24, 2011 - 04:24 AM
Kenny, put the rear blade on the Cub, and center grader blade on the Sears, it has the best belly for this.
I tried to put one on my Ford and with out removing the deck lift frame there was not enough room to get decent lift.
#23 KennyP ONLINE
  • 37,393 Thanks
  • 45,448 posts
Posted August 24, 2011 - 04:46 AM
That's what I was thinking, especially since I have the 26" tires on the back of it now. Gained a little clearance there.
