1655 snow plow
16 replies to this topic
#1 bolen1 OFFLINE
bolen1
  • 37 Thanks
  • 44 posts
Posted August 11, 2017 - 01:46 PM
Need picture and drawing with dimension for snow plow hitch for front on 1655 Massey . Just traded for tractor has 3pt. Hitch on rear. Any info would be appreciated .
#2 DMAX ONLINE
DMAX
    Addicted
  • Site Supporter
  • 592 Thanks
  • 235 posts
Posted August 11, 2017 - 07:16 PM
I just picked up a 1655 yesterday. This is a pic of the snow plow bracket on it. Is this what you need info on? I can make up a sketch with dimensions if you'd like. Pretty much the same design as the 10 - 16 tractors that I'm familiar with except this bracket is huge.
  • bolen1 and KBuzz have said thanks
#3 bolen1 OFFLINE
bolen1
  • 37 Thanks
  • 44 posts
Posted August 11, 2017 - 08:28 PM
Need that plus the long frame that goes under tractor that will raise blade . Don't have so got to make it. Thanks in advance for any and all info.
#4 DMAX ONLINE
DMAX
    Addicted
  • Site Supporter
  • 592 Thanks
  • 235 posts
Posted August 12, 2017 - 05:49 PM
I didn't have a chance today to measure things for you. I'll try to do it tomorrow.
#5 bolen1 OFFLINE
bolen1
  • 37 Thanks
  • 44 posts
Posted August 13, 2017 - 02:39 PM
Thanks. Worked on carb.got cranking and running good.Have 2 stripped holes on intake. Will start pulling of sheet metal for repainting soon.( I hope)
  • DMAX said thank you
#6 KBuzz OFFLINE
KBuzz
  • 84 Thanks
  • 45 posts
Posted August 15, 2017 - 04:38 PM
So where are the pics of this new 1655? Is there a story to go with the pics? Did anyone help you pick it up? Geeze... so many questions!
#7 DMAX ONLINE
DMAX
    Addicted
  • Site Supporter
  • 592 Thanks
  • 235 posts
Posted August 17, 2017 - 08:24 AM
Here's a picture and a sketch of the bracket. I didn't measure out the mounting holes, you can get the dimension of the front of your tractor. I layed it out in the flat showing you where to bend or weld it in order to make the 90 degree bend. I still need to get the channel on the plow measured but I'm not convinced yet that mine is correct.
Kbuzz, you're right I need to get some pics of it on here. Be patient you know I never do things in a hurry.
  • bolen1, KBuzz and secondtry have said thanks
#8 KBuzz OFFLINE
KBuzz
  • 84 Thanks
  • 45 posts
Posted August 18, 2017 - 08:20 AM
Nice sketch!
#9 bolen1 OFFLINE
bolen1
  • 37 Thanks
  • 44 posts
Posted August 18, 2017 - 09:11 AM
Thanks a bunch that drawing is perfect. On the frame as long as picture with how it actually attaches to rear and center rock shaft. Will get me close.probably will just have manual blade tilt. Got to fix hydro first broke pins.
#10 bolen1 OFFLINE
bolen1
  • 37 Thanks
  • 44 posts
Posted August 18, 2017 - 09:21 AM
  • DMAX, limebuzz, KBuzz and 1 other said thanks
#11 DMAX ONLINE
DMAX
    Addicted
  • Site Supporter
  • 592 Thanks
  • 235 posts
Posted August 23, 2017 - 07:58 PM
That's a nice looking tractor. Rear pto, I'm jealous! Here's a few pictures of the blade, if you need me to I'll get some dimensions. I was going to tonight but believe it or not there's a good bit to measure just didn't have enough time.
  • limebuzz, bolen1 and KBuzz have said thanks
#12 bolen1 OFFLINE
bolen1
  • 37 Thanks
  • 44 posts
Posted August 24, 2017 - 07:12 PM
Measurements would be great when ever you get the time. Tractor backfiring thru carb. Got to fix that.just put on new Kevlar drive belts.
#13 DMAX ONLINE
DMAX
    Addicted
  • Site Supporter
  • 592 Thanks
  • 235 posts
Posted October 20, 2017 - 11:43 AM
Here's some pictures and a sketch. The drawing is "busy", There's more dimensions to it than I realized. I may have given you more than you'll need but I'm not sure what you doing about the blade and swivel. There's a lot more to it than what I drew, But this should get you moving in the right direction. Let me know what your plans are and I'll try to help as much as I can. Looking at the channel frame on mine it looks bent up, the previous owner must of really worked the tractor hard.
  • limebuzz, bolen1, KBuzz and 1 other said thanks
#14 bolen1 OFFLINE
bolen1
  • 37 Thanks
  • 44 posts
Posted October 20, 2017 - 11:59 AM
That should get me started. I'm making a rear blade for it now.Will get on this one hopefully this winter,camping season will be mostly over. Only camp a few time in the winter months.
#15 bolen1 OFFLINE
bolen1
  • 37 Thanks
  • 44 posts
Posted March 13, 2018 - 09:39 AM
Picture of homemade snow plow frame with lots of info and specs. From Dmaximage.jpeg image.jpeg image.jpeg image.jpeg
  • DMAX, limebuzz and jpswift1 have said thanks
