Another one bites the dust
6 replies to this topic
#1 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted August 08, 2017 - 07:08 PM
Sears upper grill that is. This was my good one too.
Now I have two to rebuild.
My son was mowing tonight and I saw he was done, but I think he decided to mow some of the field. He pulled up in front of the wood gates and for some reason his foot came off clutch and in 2 hi, the ole girl lunged right onto the gate, blew the grill apart. He hit so hard it pushed the hood into the steering wheel and dent the edge. It was a bad night, I came on and our hot water heater is leaking all over the basement floor.
.....and of course we have sideways pics again
Edited by TAHOE, August 08, 2017 - 07:09 PM.
  • DougT, KennyP, Cvans and 2 others have said thanks
#2 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted August 08, 2017 - 08:14 PM
That there is a bad day. Hopefully it goes better for ya tomorrow?
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,981 Thanks
  • 9,626 posts
Posted August 08, 2017 - 08:17 PM
Ouch! Looks like it got into the engine, too.
#4 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted August 09, 2017 - 06:27 AM
Probably not, I am about 2 days behind on work needing to be done at work, seems everyone puts in orders at the same time.
I had to take off early yesterday too to take dog to vet for some type of muscular/skeletal issue, he hurts every time he gets up and is moving real slow
I don't think so, it might have hit the air cleaner a little, but I didn't see any marks on it.
My son started to get tools to take it apart, I told him to just pull it in the barn, I didn't even want to deal with it.
  • chieffan said thank you
#5 chieffan ONLINE
  • 9,582 Thanks
  • 6,419 posts
Posted August 09, 2017 - 07:31 AM
Messed it up real good for sure.  When we get behind somebody always creates more work for us.  This winter build a frame mount grill guard.
  • TAHOE said thank you
#6 KennyP ONLINE
  • 37,487 Thanks
  • 45,503 posts
Posted August 09, 2017 - 07:40 AM
At least you have the pieces to rebuild it. My ST/16 has a bunch missing, gonna be harder to fix it.
#7 indslpwr04 OFFLINE
indslpwr04
  • 87 Thanks
  • 62 posts
Posted August 24, 2017 - 11:35 AM
At least it broke for a reason.  Mine fell apart just from vibration during the tractor parade after weeks of repair.  I ordered 2 part epoxy resin made by smooth cast from amazon.  It is a black mix. and dries really fast. i used aluminum foil tape to make forms of where i needed it to stay and drilled flow holes to get the 3 separate areas to share common resin.  I epoxied in rivet nuts for the hinge bolts and drilled into the fiberglass pieces i used on the first repair to bond everything together.
  • TAHOE and Sawdust have said thanks
