Upcoming Project
16 replies to this topic
#1 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted August 06, 2017 - 03:37 PM
Once I get the Bolens LK running again, I have a project waiting. I have a old possible Murray with a B&S 20 HP engine on it (engine was added, opposed twin) that is supposed to run. I'll bring it up and we'll see. If that does run, the engine will be a replacement into a JD 265 with a knock. It has the Kawasaki 17HP in it. Should be a fun project. This 20 HP has an oil filter, needs some tins which I have. Just got to get the LK done and out of the way!
  • olcowhand, Gtractor, Trav1s and 7 others have said thanks
#2 jms180 OFFLINE
jms180
  • 1,753 Thanks
  • 1,675 posts
Posted August 06, 2017 - 04:47 PM
nice Kenny I always enjoy you projects
#3 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 06, 2017 - 07:18 PM
You back from Staycation then Kenny?   :smilewink:
#4 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted August 07, 2017 - 04:49 AM
Yeah, hope nothing else breaks for me!
  • olcowhand said thank you
#5 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted August 07, 2017 - 09:39 AM
I went out back and got the B&S engine #'s. It's a 460777 1276-01. Around 45 cu. in. I may drag it up here in a bit.
#6 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted August 07, 2017 - 04:16 PM
I brought the old Murray up today! Looks like it was a stout machine at one time. And yes, that is part of a Sears lift on the back.
Id tag reads as follows:
4-39004X92
Date of manufacture: 0134
Anywho, The 20HP ran for a few seconds on carb cleaner! :dancingbanana:  A bit more playing around and I'll have it going strong.
#7 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted August 07, 2017 - 04:45 PM
I hooked a temp fuel tank to it and a bigger battery and it fired off and ran til I grounded the kill wire. I don't see a rectifier anywhere, so don't know if it's charging.
  • olcowhand and gopher have said thanks
#8 jms180 OFFLINE
jms180
  • 1,753 Thanks
  • 1,675 posts
Posted August 07, 2017 - 04:58 PM
I see some progress thanks for the pictures Kenny
Edited by jms180, August 07, 2017 - 04:58 PM.
#9 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 07, 2017 - 06:49 PM
If it has a manual PTO, then likely it just has a 3 amp charge circuit with the little diode in the stator output wire.
  • KennyP and SupplySergeant have said thanks
#10 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted August 08, 2017 - 04:59 AM
It is most likely that way, Daniel. But I just happen to have some possible donor stators. Have to check that out.
EDIT: I have 2 horizontal twins that had electric PTO's on them. Hoping the flywheel and stators will interchange.
Edited by KennyP, August 08, 2017 - 06:11 AM.
Added Content
#11 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted August 08, 2017 - 10:24 AM
Well, I SOL on the charging system. I don't have anything better then what is there right now. But, I did see something interesting on the tie rod ends.
Ever seen these with zerks? Spindles are oil lube only, but you can grease the tie rod ends!
And I have the hood for this old girl.
Thinking about taking her for a drive!
#12 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted August 11, 2017 - 05:29 AM
Thinking about leaving this as is except getting the hood remounted. The starter needs repair/replaced. I have another just like it, but the top bushing is bad. Can't buy just the bushing, have to replace the whole top end. They wanted $45 for that. Found a new starter on Ebay for $24.14 and free shipping.
I'll get a flywheel and stator for the Kohler 25HP and put it in the JD 265. It's a bit skinnier and about the same length wise. Plus, it will have a 15 Amp charging system for the electric clutch.
#13 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,131 Thanks
  • 10,199 posts
Posted August 11, 2017 - 07:18 AM
So, you'll have saved a Murrey while a JD goes wanting. ???
#14 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted August 11, 2017 - 07:34 AM
The JD will get the bigger engine! More power!
This old Murray has a lot going for it. It still has the original battery hold down among a lot of other cool things. Would be a good trailer puller and a few other things with the sleeve hitch.
#15 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted August 11, 2017 - 10:27 AM
I wanted to see how it would look with the hood on correctly. Had to trim some off the bottom inside of the hood and take the muffler off to get it on though. To put the muffler back on would entail cutting about 4" up the front of the grille. Or add on to the exhaust pipes and put the muffler lower? Definitely need a bumper then!
  • LilysDad said thank you
