John Deere 318 Mule
No replies to this topic
#1 K3522 OFFLINE
  • 7 Thanks
  • 21 posts
Posted June 21, 2011 - 09:24 AM
I just traded my 316 for a 318 and the mule does not have the rod that shows when the tension is in the right range. I see where it broke off and I can take a allen wrench and cut the short leg and have if welded on to replace the L-shaped rod but need a picture of the mule without the cover to see it's correct position.
I could probably just tighten the tension until there is only about a 1/2" of deflection between the mower deck pulley and the mule. Then if it chirps when the deck is engaged I could tighten some more but would kind of like to have the rod and mule face plate gage working.
