New to the GT talk
16 replies to this topic
#1 iPfreely79 OFFLINE
iPfreely79
  • 3 Thanks
  • 6 posts
Posted August 03, 2017 - 03:29 PM
Hi everyone,
I got a Ariens gt 17. Old tractor is old but I'm bringing it back to running order. Would like to know how to put it in neutral? So I can push it under my big tree out of the sun. So its not so dang hot to work on.
  • Oldford said thank you
#2 Piddler2 OFFLINE
Piddler2
  • 5 Thanks
  • 14 posts
Posted August 03, 2017 - 05:35 PM
Mine has free wheel valve under the seat pan/rear deck.Lift the lever and it should p I should easy
  • Jazz said thank you
#3 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted August 03, 2017 - 06:23 PM
:welcometogttalk:
#4 TomLGT195 OFFLINE
TomLGT195
  • 3,831 Thanks
  • 2,815 posts
Posted August 03, 2017 - 06:42 PM
Welcome to GTTALK. Pics always help guys with your questions. Plus we like tractor pics
#5 shorty ONLINE
shorty
  • 5,485 Thanks
  • 5,263 posts
Posted August 03, 2017 - 07:53 PM
Welcome to GTt!
The release is on top of the charge pump.
#6 Scrapr65 OFFLINE
Scrapr65
  • 22 Thanks
  • 24 posts
Posted August 03, 2017 - 08:19 PM
Welcome to GT talk. :wave:
#7 iPfreely79 OFFLINE
iPfreely79
  • 3 Thanks
  • 6 posts
Posted August 03, 2017 - 08:37 PM
Thanks everyone.
#8 boyscout862 OFFLINE
  • 12,859 Thanks
  • 9,173 posts
Posted August 03, 2017 - 08:54 PM
Welcome to GTT. Check our Manuals Section for the info that you need. Good Luck, Rick
#9 iPfreely79 OFFLINE
iPfreely79
  • 3 Thanks
  • 6 posts
Posted August 03, 2017 - 08:55 PM
What I have done so far. I bought new tractor lug tires and had the rims re powder coated white. Replaced the front PTO bearings. That was a crash course. Never worked on a PTO before. Had a friend show me/ help replace points and condenser. Replaced the fuel filter. Fuel line coming out of the tank was setup way wrong. Someone put copper line and then a put vacuum line on the end up over the bend coming out of the top of the tank. Replaced it with some1/4 inch  weed eater line material i got from A&G auto parts put a compression fitting on the end that inside the tank for weight. Then sealed the hole around line at the top of the tank with black gasket sealant. I had it running today but kept stopping like it was out of fuel.I think there is a air pocket in the line. So going to pull the line off the carb and turn the electric pump on see what happens. I will put pictures up once i find them.
#10 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 862 Thanks
  • 719 posts
Posted August 03, 2017 - 09:31 PM
Welcome! Ariens is a nice machine. Should be a good project. Where is Armstrong PA? Or do you mean Armstrong County?
#11 jimmy G ONLINE
jimmy G
  • 1,197 Thanks
  • 779 posts
Posted August 03, 2017 - 09:44 PM
out in the yard under a tree is a good place to do that kind of check, from what you have said sounds like a piece of crud getting pulled into the main jet, when the engine quits the crud is released, use a glass bottle or jar when checking the pump and look for ANYTHING, has to be nothing, a fuel filter is a must on old tractors
  • iPfreely79 said thank you
#12 oldedeeres OFFLINE
oldedeeres
  • 9,508 Thanks
  • 4,770 posts
Posted August 04, 2017 - 01:19 AM
Welcome aboard!
#13 iPfreely79 OFFLINE
iPfreely79
  • 3 Thanks
  • 6 posts
Posted August 04, 2017 - 08:53 AM
Armstrong county. Cowansville Pa
  • Marty'70 said thank you
#14 iPfreely79 OFFLINE
iPfreely79
  • 3 Thanks
  • 6 posts
Posted August 04, 2017 - 07:02 PM
well my friend Al came over today. We found out that the inlet seat on the carb was plugged. Its back up and running and This tractor is a tank. Never even bogged down threw the grass like 4f high!! Best investment EVER
#15 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,366 Thanks
  • 1,338 posts
Posted August 04, 2017 - 08:35 PM
Good!  Now you can invest some money in a camera so we can see some pictures of your tractor!! :D
Oh!  Welcome aboard!
