jd 112l engine swap question
7 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 21, 2011 - 08:34 AM
im putting a 12hp briggs model 281707 in my 112l was wondering if anyone could tell me what i need to do for the wiring to the engine and also if anyone has a manual for this tractor thankyou
#2 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 21, 2011 - 03:28 PM
well i have it ne tried to start it and all i get is the click from the solenoid any ideas?
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted June 21, 2011 - 03:39 PM
Usually when I get that, it's a bad cable or connection between the solenoid and the starter. Could be a bad starter or solenoid also... I don't think it's a safety switch, you shouldn't normally get the click if it's that.
  • ace69xxx2000 said thank you
#4 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 21, 2011 - 03:46 PM
ok thank you i will check those ideas now i do know the starter is good i had the engine running in the tractor it cam out of another question i have is i forgot how the drive belt came off can anyone tell me how it goes back on thanks again
#5 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 24, 2011 - 10:56 AM
Ok now I got it running it was a bad battery cable now I have a problem that it will go about 15 feet and die if I disengage the hydro it will stay running no problem and I was told that that's what it would do for the previous owner and they were told it had a bent valve so now it has the same problem with a different engine that I know is good any ideas and what could cause this its getting really frustrating thank you
#6 Tmo OFFLINE
Tmo
  • 361 Thanks
  • 486 posts
Posted June 24, 2011 - 12:33 PM
Time to start checking safety switches, seat switch, neutral start switch, pto switch, etc.
#7 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 24, 2011 - 01:57 PM
Ok the seat switch is bypassed the neutral switch seems good because if you don't have the pedal in all the way it won't do anything but I did see a yellow wire from the pto switch that has a blue plug on isn't hooked to anything and I can't find anything it hooks to the other wire from that spot is yellow and runs to the ignition switch and then from there to the voltage regulator any Idea what that is supposed to be hooked to thank you
#8 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 25, 2011 - 08:50 AM
There is a 112 wiring diagram in the manuals section. Download it and have a look at the diagram. That should help you sort it out. I'm not familiar with the 112 but somw of the PTO switches have safety interlock contacts. A PO may have changed the wiring at some point so it is best to have a look at the diagram to see what's up.
