Need help ID engine on my new S24
8 replies to this topic
#1 hddlh OFFLINE
hddlh
  • 46 Thanks
  • 80 posts
Posted July 31, 2017 - 08:26 AM
There is not a tag on it that I see on engine.  Looks like original 10 hp Briggs, but I would like to know what model.  It doesn't run now and may need some parts, so knowing exactly what it is will may things easier.
Also where would serial number of tractor be located, is it stamped in frame?
thanks
#2 TAHOE OFFLINE
TAHOE
  • 8,165 Thanks
  • 5,758 posts
Posted July 31, 2017 - 08:47 AM
The tractor serial number should be located on the frame rail under the engine, right side.....if they are there. I've owned 2, neither one had distinguishable markings.
The engine tins should have their serial number stamped into the tins, you can usually date motor with those.
  • hddlh said thank you
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,856 Thanks
  • 10,036 posts
Posted July 31, 2017 - 08:50 AM
The engine tins should have their serial number stamped into the tins . . .
Behind, below carb?
#4 TAHOE OFFLINE
TAHOE
  • 8,165 Thanks
  • 5,758 posts
Posted July 31, 2017 - 11:10 AM
Behind, below carb?
Actually if I remember correctly, the numbers on my S23 are stamped on this tin of the motor.
#5 DougT ONLINE
DougT
    Dog Approved
  • 7,069 Thanks
  • 5,056 posts
Posted July 31, 2017 - 11:17 AM
Tahoe, If they were there, it would have an I.D.plate riveted there in the holes.
If they are stamped in the shroud, they would be stamped on the edge by the carb, across the top by the plug, or over by the starter gen on the edge. I've seen them in all 3 places if it didn't have the plate.
#6 TAHOE OFFLINE
TAHOE
  • 8,165 Thanks
  • 5,758 posts
Posted July 31, 2017 - 11:27 AM
I'll have to check tonight, been awhile since I've look at the thing :D
#7 boyscout862 ONLINE
  • 13,429 Thanks
  • 9,379 posts
Posted August 01, 2017 - 06:52 AM
The engine looks like an old cast iron Briggs and Stratton. My old AC and Simplicities had the same engine. The model number on them is 243341. They are great engines and have run for a long time. Look in our Manuals Section for the info that you want. Good Luck, Rick
#8 TAHOE OFFLINE
TAHOE
  • 8,165 Thanks
  • 5,758 posts
Posted August 01, 2017 - 07:18 AM
i looked last night. We were both correct, my model/serial number is on that side tin, but you are correct, it's an ID plate riveted on there.
#9 hddlh OFFLINE
hddlh
  • 46 Thanks
  • 80 posts
Posted August 02, 2017 - 12:55 PM
Found both engine info and tractor s/n, thanks for the assistance
