Sears ST/16 Tractor Ballpark Price
sears st/16 tractor
7 replies to this topic
#1 Landofnone OFFLINE
Landofnone
  • 1 Thanks
  • 3 posts
Posted July 31, 2017 - 08:07 AM
I'm in the process of trading for a Sears ST/16 with some attachments. The man claimed it ran 2 months ago and now it just stop running for him
I think It could be the carburetor just needs TLC/rebuild, it could also be the coil gone bad/lost adjustment/rusty connections between the coil and the flywheel. Bad starter/not enough juice, the air filter could be needed a replacement, flywheel losing magnetism.
That is all i can think of that may not be allowing the engine to fire up. I will be receiving a video from him in attempt to start it later on today.
Update: As i was typing this up, some new photos came to light.
Edited by Landofnone, July 31, 2017 - 08:42 AM.
#2 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted July 31, 2017 - 08:54 AM
That tractor not running with those attachments, maybe 150-200.
Attachments have the worth, that tractor is in pretty rough shape.
The 5 blade disc is not super common.
Tractor is a '74 or '75 model
You could have any number of issues
SSI module has finally burnt out ( about $150 for modern day replacement)
could be just a bad ignition switch shorting out ignition module
Wire feeding module from stator has shorted out.
Stator has wen bad.
Head has dropped a valve which is common on the OH160.
#3 Landofnone OFFLINE
Landofnone
  • 1 Thanks
  • 3 posts
Posted July 31, 2017 - 09:54 AM
Stator has wen bad.
He is selling the whole lot for $200. My item that i am willing to trade him for, is usually valued at $400 last time i checked. I was coming here to make sure i wasn't being stupid as i feel like i am making a mistake if i proceed with the trade. And it is 35 mi away at that. I have a buddy that knows a lot more about engines than i do. But, he is a welder and don't hardly get any days off. And when he is off, he is not doing a darn thing.
  • TAHOE said thank you
#4 JBRamsey ONLINE
JBRamsey
  • 1,412 Thanks
  • 813 posts
Posted July 31, 2017 - 11:00 AM
That's a backwards trade. If you want it, I'd offer him a $ 100 bill but that's only because of the attachments and keep whatever it is you are thinking about trading.
#5 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted July 31, 2017 - 11:18 AM
you can have several hundred in that tractor before you know it.
I bought a 1977 16/6 ( ST16) for $150 with deck and 3pt a few years back. Tractor was in good condition, but he told me it just quit starting.  I researched it and knew a few things it could be. Ended up mice built a nest inside the tins, caused overheating of the head and it dropped the exhaust valve. $120 and it was running. 8 months later it burnt up the SSI module, another $150 to fix that, plus a carb cleaning, new voltage regulator, etc.
It's worth what ever you are willing to pay and he is willing to sell it for. Me, I may go 150 just for implements, tractors is really rough though.
#6 Landofnone OFFLINE
Landofnone
  • 1 Thanks
  • 3 posts
Posted July 31, 2017 - 01:56 PM
Not worth getting. Understood. I will find something else. Thank you
#7 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,120 Thanks
  • 4,887 posts
Posted July 31, 2017 - 06:01 PM
Gave $125 for this one at a huge consignment auction that had bidders from all 48 of the continental U.S.of A. states.
Ran perfect, tires held air, and had a brand new battery for the sale.
Edited by Gtractor, July 31, 2017 - 06:01 PM.
#8 EricFromPa ONLINE
EricFromPa
  • 3,524 Thanks
  • 3,070 posts
Posted July 31, 2017 - 06:58 PM
I would give $300-$400 for it.
$100-$150 for the 3 point if it has the center link
Rear attachments are usually $100-$150+ each
42" Deck if Solid is worth $100 48" Deck if solid $150+
Wheel Weights $50
Tractor maybe $150 but I would not be buying it for the tractor.OHV Tecumseh engines are Evil. They don't like me lol
