Charging or not
5 replies to this topic
#1 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted July 30, 2017 - 12:33 PM
My cub cadet 129 is not charging. I put a new starter generator on was tested good now where do I look?
It will run with the battery charger on it then about 20 mins after its off the charger.
#2 chieffan ONLINE
  • 10,201 Thanks
  • 6,662 posts
Posted July 30, 2017 - 12:35 PM
Voltage regulator, or broken wire in the circuit.
Edited by chieffan, July 30, 2017 - 12:35 PM.
  • boyscout862 and old coot have said thanks
#3 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,087 Thanks
  • 589 posts
Posted July 30, 2017 - 04:34 PM
I also say broken wire . Bad connection or bad ground also.
#4 GWest OFFLINE
GWest
  • 548 Thanks
  • 499 posts
Posted July 30, 2017 - 05:47 PM
Good manual that covers the starter/generator
http://gardentractor...service-manual/
Garry
#5 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted July 30, 2017 - 07:12 PM
I'll start looking into the mentioned... Thanks guys
#6 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted August 01, 2017 - 05:25 PM
Well I need a starter generator mine would start the tractor. Then looked inside to find broken wires bearing was grinding at the rear end and it was about half full of water for some reason.... Maybe liquid cooled generator..hmmm oh well now I'm on the hunt for a starter generator...
Found no broken wires in the harness or bad dirty connections. Sanded lightly even tho they were good just to be safe.
