990 keeps shutting
4 replies to this topic
#1 gary990 OFFLINE
gary990
  • 15 Thanks
  • 42 posts
Posted July 29, 2017 - 02:58 PM
what does it mean when you open the gas all the way up then after 15 or 20sec. it kills the motor, then it will start right up.  i changed fuel filter blew out the lines, when it kills the fuel filter is all most full. unless it could be the new carb i put on it, but it runs great. any one got a better idea what i could check.
  • Sawdust said thank you
#2 VTXrider ONLINE
VTXrider
  • 517 Thanks
  • 376 posts
Posted July 29, 2017 - 04:31 PM
That is a sign the float in the carb is not set properly.
Edited by VTXrider, July 29, 2017 - 04:36 PM.
#3 gary990 OFFLINE
gary990
  • 15 Thanks
  • 42 posts
Posted July 29, 2017 - 05:08 PM
thanks never thought about the float. that will be a trick for me i have never done that. ill have to take it to a guy that know how to work on that. thank you for the tip. good thinking.
#4 Sawdust ONLINE
Sawdust
  • 5,675 Thanks
  • 3,379 posts
Posted July 29, 2017 - 05:54 PM
I agree, you got pics of your 990.
#5 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,176 posts
Posted July 30, 2017 - 07:56 AM
Before trying anything else. Loosen the gas cap alot. Try running the tractor and see what happens. Sometimes this happens because the gas tank cap vent gets plugged. Also check that the fuel line isn't kinked or restricted(methanol makes the rubber swell). Good Luck, Rick
  • VTXrider and Sawdust have said thanks
