Calgary - Kwik way loader on some kind of sears tractor ($750)
10 replies to this topic
#1 Mustard Tiger ONLINE
Mustard Tiger
  • 81 Thanks
  • 87 posts
Posted July 29, 2017 - 07:27 AM
https://www.kijiji.c...gationFlag=true
I don't know anything about sears machines but even if it is junk the loader is worth the price.
  • Traill95 said thank you
#2 KennyP ONLINE
  • 35,059 Thanks
  • 44,081 posts
Posted July 29, 2017 - 08:00 AM
That would be nice to have, for sure!
#3 secondtry OFFLINE
secondtry
  • 1,274 Thanks
  • 1,038 posts
Posted July 29, 2017 - 08:11 AM
  Looks like a money pit to me, that said if it was closer I would be off to look. Don
  • 1oldbuzz said thank you
#4 chieffan OFFLINE
  • 8,799 Thanks
  • 6,034 posts
Posted July 29, 2017 - 10:50 AM
A guy could get lucky and not have to put much in the loader.  Then again if cylinders need rebuilt, new hoses, control valve rebuilt and so on.  If one can get the onan to run score a plus, if not, more $$ to repair.  50/50 deal there.
#5 Xrperry ONLINE
Xrperry
  • 925 Thanks
  • 705 posts
Posted July 29, 2017 - 10:54 AM
Just wondering, I know a lot of you guys want a front end loader. My question is how much weight will one pick Up? I can't see one picking up a full load of gravel or dirt, maybe it can, but you need a bunch of counterweight. Hard on the tractor?. Anyway maybe someone can give me some info.i have passed up a few for cheap.
#6 Mustard Tiger ONLINE
Mustard Tiger
  • 81 Thanks
  • 87 posts
Posted July 29, 2017 - 04:16 PM
I think you are limited by the weight your tractor can support before you run into limits on the loader.  As far as I know, they are 800 PSI.  Which gives you 630 pounds of lift capacity for a 1 inch cylinder, and there are two of them.  You aren't getting 1200 pounds because its lifting behind the weight, but it should be more than enough.
  • Traill95 and Xrperry have said thanks
#7 secondtry OFFLINE
secondtry
  • 1,274 Thanks
  • 1,038 posts
Posted July 30, 2017 - 11:01 AM
I just installed pallet forks on my 8N. Before doing this I cruised the web looking for load capabilities of the tractor. The consensus seamed to be under 1000 lbs. I remembered an N series from my youth that seamed to be moving much more. I spent several days building a replacement for the bucket to mount the forks. When I got done I was able to unload pallets of wood pellets from a trailer. One ton per pallet. It took an insane amount of counter weight and is almost impossible to steer but it got the job done. I will try to upload pics later. Don
  • Cvans said thank you
#8 secondtry OFFLINE
secondtry
  • 1,274 Thanks
  • 1,038 posts
Posted July 31, 2017 - 08:46 AM
Pictures of my fork build. Don
#9 Cvans ONLINE
  • 6,001 Thanks
  • 5,865 posts
Posted July 31, 2017 - 11:03 AM
Nice looking forks. You have to remember that 1000lbs can quickly become twice that load on the axle if you drive into a rut or pot hole. I have a Ford 850 with a loader sometimes when the loader is full and I hit a bump I worry about that light front axle. Good so far but!
  • secondtry said thank you
#10 secondtry OFFLINE
secondtry
  • 1,274 Thanks
  • 1,038 posts
Posted July 31, 2017 - 04:04 PM
     I have been lifting 1 ton pallets of wood pellets. Since lifting the pellets took almost all weight of the rear tires I have to assume that the weight of the pellets and the weight of the tractor are balanced on the front axle. 2000 + 4700 + about 1000 for the loader frame and forks. 8000 lbs on the front axle would not surprise me. Add any shock loading and the front end is overloaded X 10. Traveling with this load is very slow and cautious. Traveling with this load more than a couple inches of the ground is insane. Don
#11 Cvans ONLINE
  • 6,001 Thanks
  • 5,865 posts
Posted July 31, 2017 - 05:03 PM
Good to hear that you've thinking about it too. I didn't want to get too scary about it. I have a friend that was almost crushed to death when his Cockshutt tractor with a loader broke in the middle. Wish there was someplace a guy could find the load ratings on tractor front axles.
