Kohler Command CH22 Coils
5 replies to this topic
#1 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 320 posts
Posted July 28, 2017 - 06:21 AM
Just had a coil go bad on my CH22 and wondered if anyone had changed theirs over to the conventional, single kill wire, magneto coils and done away with the SAM (spark advance module).
#2 Bolens 1000 ONLINE
  • 14,989 Thanks
  • 18,141 posts
Posted July 28, 2017 - 06:43 AM
If you can get me the spec and serial I can get you in the right direction to the conversion if possible on your motor
Number on your current coils will help as well
  • MolonLabe said thank you
#3 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 28, 2017 - 06:54 AM
#4 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 320 posts
Posted July 28, 2017 - 07:13 AM
The CH22S spec is PS-66527 and the coil is Kohler 24 584 36S
Thanks!
#5 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted July 28, 2017 - 07:57 AM
Yes it is easy to do. You will need part number 25 707 03-s comes with 2 new coils and the wiring needed. The kit runs around $90.00
#6 Bolens 1000 ONLINE
  • 14,989 Thanks
  • 18,141 posts
Posted July 28, 2017 - 07:58 AM
You can convert them to the 25-703-03 kit ,
I do stock them if needed
http://bolenspartsan...172-24-755-173/
