I've been looking for a 220 volt welder for the past year to because my Millermatic 135 110 volt mig doesn't penetrate enough on thicker steel. I found it on CL the PO just wanted it gone because it was taking up space. He wanted $75 (they usually go for over a $100 around here) so I offered him $60 and he took it. It also came with several containers of welding rod. Now I can do some modification to my 5th wheel trailer like adding a 2" hitch so I can slide in a bike rack for our 4 bikes when we go camping. This will make my wife very happy and make life a little easier!
#2
OFFLINE
Posted July 24, 2017 - 11:05 PM
- boyscout862 and Mark 149 J. have said thanks
#4
OFFLINE
Posted July 25, 2017 - 12:06 AM
I picked my Tumbstone out of a dumpster in 89 225 AC DC. In 98 the fan had to be oiled. Still runs and sounds fine, I probably should pull the cover and clean and lube again. I still have the Craftsman buzz box it replaced. This spring I got at auction a 300 amp Lincoln inverter welder that makes the other two seem like junk. Don
- boyscout862, Sawdust and Mark 149 J. have said thanks
#5
ONLINE
Posted July 25, 2017 - 07:04 AM
Great find. About the only thing that goes bad on them is cords will deteriorate over a long time. The sure isn't any fault of the welder though. Will do about anything you may want around a home shop. Of course all the big boys use the gas wire welders now days.
#6
ONLINE
Posted July 25, 2017 - 08:04 AM
Always great to add a tool to the workshop. I bought mine 37 years ago, brand new. It was $135 on sale in a local hardware store. It has paid for itself a dozen times over. Later, I bought the Wisconsin powered equivalent for use in the woods on my shoveldozer. It has a crank start Wisconsin THD. It is another tool that paid for itself many times over. I found that the best accessory for the welder is a heavy steel welding table. Good Luck, Rick
- Sawdust and Mark 149 J. have said thanks
#7
OFFLINE
Posted July 25, 2017 - 08:56 AM
I got one about ten years or so from a guy he ask $100.00 for it . Again just wanted it gong , at the time they were at about $300.00 at homedepot
, I got the miller mig, and my gas power welder / generator
Patrick.
#8
OFFLINE
Posted July 25, 2017 - 11:01 AM
I found it on CL the PO just wanted it gone because it was taking up space. It also came with several containers of welding rod.
Look for some rods starting with 70 like 7018 etc. Also called Jet rods, they weld a lot cleaner than the 60 series
#9
OFFLINE
Posted July 25, 2017 - 11:05 AM
I believe that is what it came with. Thanks for the information!
- boyscout862 and Sawdust have said thanks
#10
OFFLINE
Posted July 25, 2017 - 11:11 AM
The first thing I looked for were cracks in the cords. There was none and they are very nice and pliable. We inherited a tombstone welder from my grandpa back in the 80's. It was so old that after a couple of years the cords started to crack really bad. I never got to use it again. I do remember it being very heavy for it's size.
- boyscout862 said thank you
#11
OFFLINE
Posted July 25, 2017 - 11:32 AM
I have leads that came with my old Craftsman that are so old all the insulation has fallen off. Still work fine for ground. Just have to make sure the other lead is in good shape. Don
#12
OFFLINE
Posted July 25, 2017 - 11:54 AM
The 70 series rods are also know as low hydrogen rods normally are not compatible with a welder like yours. You might be able to make it work but it will not be enjoyable. If it was the AC-DC version than yes. It has to do with the open circuit voltage of your welder. They do make AC versions of that rod for your welder and they should work just fine. Here is the info from the Lincoln site.
http://www.lincolnel...incolnElectric)
LINCOLN® 7018 AC
AWS: E7018 H8
Top Features
- AC polarity welding
- Low open circuit voltage operation
- Minimal spatter
- Capable of cold re-strikes
Typical Applications
- General fabrication
- Tack and skip welds
- Thin sections
Welding Positions
All, except vertical down
#13
OFFLINE
Posted July 25, 2017 - 12:17 PM
Awesome!
- Cvans said thank you
#14
ONLINE
Posted July 25, 2017 - 01:58 PM
- Cvans, Sawdust, Oldford and 1 other said thanks
Also tagged with one or more of these keywords: lincoln, welder, tombstone
Home & Garden →
Tool Shed →
Good Laugh!(a.k.a. my welding)Started by Mark 149 J. , Jan 20, 2018 ![]() |
Barn →
Mechanical & Hydraulics Forum →
Tractor Tools(welder)Started by boyscout862 , Mar 20, 2013 ![]() |
Home & Garden →
Tool Shed →
Has Anyone Used This Welder?Started by bgkid2966 , Feb 11, 2013 ![]() |
