Pull Behind Mower, Self Powered
pull mower 54 inch pull behind mower
23 replies to this topic
#16 poncho62 ONLINE
poncho62
  • 1,748 Thanks
  • 1,665 posts
Posted August 12, 2017 - 07:33 AM
On mine, I just used a set of jumper cables and started it with that. Kept them under the tractor seat.
  • KennyP, Sawdust and MNGB have said thanks
#17 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted August 12, 2017 - 07:44 AM
That's a good idea!
#18 MNGB ONLINE
MNGB
  • 2,127 Thanks
  • 1,408 posts
Posted August 13, 2017 - 10:38 AM
Hi that's what I use with my Swisher a set of light wt jumpers works good actually engines with a compression release don't draw real heavy amps when starting. I just ordered some Nema 10-20 heavy duty straight blade electrical plug in's and receptacles these work good can handle the amps
  https://www.amazon.c...DKIKX0DER&psc=1
https://www.amazon.c...0?ie=UTF8&psc=1
Edited by MNGB, August 13, 2017 - 10:39 AM.
  • KennyP and Sawdust have said thanks
#19 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted October 03, 2017 - 04:07 PM
This idea just keeps coming up every time I look at the deck. I have come up with some good trailing wheels for it, ordered the bearings for them today. May become an over the winter project! Give me time to source parts!
  • MNGB said thank you
#20 Bob White12 OFFLINE
Bob White12
  • 134 Thanks
  • 132 posts
Posted October 03, 2017 - 09:20 PM
I did one a while back using a Ford deck. Worked well as a tow behind.....The part where the engine sits was the front frame of the tractor I got the engine from.
I wanted to use the deck mower to do a hill in front of my house. I had to try and push the mower up the bank, but it turned out to be too heavy. Wouldn't push it up to the top of the hill.
I solved this by building a frame with swivel wheels to mount a push mower on . Not as wide, but works great.
wow that sure looks cool bet it will work great in the hills!!!
#21 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted October 04, 2017 - 12:29 PM
Here's one of the trailing wheels. Carlisle Semi-Pneumatic 13X5.00-6. Hub is 5.5" wide. Takes a standard bearing set for 3/4" axles.DSCN3357.JPG
  • Sawdust and MNGB have said thanks
#22 UncleWillie OFFLINE
  • 15,669 Thanks
  • 8,761 posts
Posted October 05, 2017 - 07:18 PM
Ahhh you have a Hemorrhoid too. My Poulan was so bad it is now parked in the weeds the deck is in a pile of other parts. The problem with that deck is the spindles are lousy. I replaced mine every other year because they just fall come apart. Something for you to keep in mind.
#23 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted October 06, 2017 - 05:38 AM
These spindles seem to be in good shape and are greasable, so the newer type.
#24 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted October 06, 2017 - 03:34 PM
Got the bearings in for the wheels! But you cannot find a 3/4" spindle anywhere! :wallbanging:  Gotta fab something up myself!
