Backfire?
9 replies to this topic
#1 Ariensn8n OFFLINE
Ariensn8n
  • 36 Thanks
  • 26 posts
Posted July 23, 2017 - 09:53 AM
So I have this pretty sweet S-16H. around 1100 hours on it runs great but every now and then I shut it off and a few seconds later wham!! not every time though. Any Idears on how to get it to stop. It has had its oil changed every 50 hours since day 1 PO said he did and that's why hour meter is on it so I have continued with it also said its done that since he bought it in 1977.
#2 tater195 ONLINE
tater195
  • 2,066 Thanks
  • 1,372 posts
Posted July 23, 2017 - 10:18 AM
the engine continues to spin after key is turned off. Unburnt fuel ends up in the hot muffler and ignites. Lowering the throttle to idle prior to shutting it off helps.
  • boyscout862, chieffan and Ariensn8n have said thanks
#3 shorty ONLINE
shorty
  • 5,268 Thanks
  • 5,160 posts
Posted July 23, 2017 - 10:35 AM
My experience with a k341 is it's best just above an idle. Each engine has it's own sweet spot for starting and shutting off.
#4 dodge trucker OFFLINE
dodge trucker
  • 2,296 Thanks
  • 3,013 posts
Posted July 23, 2017 - 12:28 PM
might be adjusted just a bit lean...  what you describe was a notorious issue with engines in the later 80s and newer because they were calibrated lean and could not be compensated for. that is why carbs on newer machines have the silly solenoids sticking out the bottom of the carb to shut fuel off as soon as the engine is killed to prevent that very issue...  may be a partly plugged jet somewhere within your carb too.
how much slop in the throttle shaft? that will allow more air in and lean things out too.
  • boyscout862 and Ariensn8n have said thanks
#5 dodge trucker OFFLINE
dodge trucker
  • 2,296 Thanks
  • 3,013 posts
Posted July 23, 2017 - 12:31 PM
just noticed your location... Kewanee IL huh?  Don't remember where that is within this lousy state think  it is kinda by Peoria?
I'm in IL too.... Kankakee area....  and have a few of these machines myself.
are these machines as hard to find in your neck of the woods as they are here?
around here if it says "Ariens" on it, chances are about 8.5 out of 10 it is a snow blower.
#6 Ariensn8n OFFLINE
Ariensn8n
  • 36 Thanks
  • 26 posts
Posted July 23, 2017 - 04:05 PM
Thanks for the reply's all!!  I'm 45 miles NW of Peoria and 45 miles SE of quad cities! I was in Kankakee last summer I bought a 64-6 c/60 grill for my66 c/10 I took 78 to 93 to 40 to 17 boring 3 hour trip yep And yea I haven't seen many of them either.
#7 Billy M ONLINE
Billy M
  • 624 Thanks
  • 536 posts
Posted July 24, 2017 - 09:09 AM
I have a GT18 with a K361 in it that does the same thing...occasionally.  I do run it on the rich side though to help keep it cool.  I've never fouled a plug, but she will puff some black smoke at times.  I try to let it idle a little bit before I shut it off.  It does help, but it still does it sometimes.  It's not so bad now that I'm used to it.  The first couple times made me jump!
  • Alc and Ariensn8n have said thanks
#8 Ariensn8n OFFLINE
Ariensn8n
  • 36 Thanks
  • 26 posts
Posted July 24, 2017 - 04:58 PM
the pause is what gets me every time! sit there and wait then BANG!! seen it near dusk once flame is about 4 5 in long
#9 Ariensn8n OFFLINE
Ariensn8n
  • 36 Thanks
  • 26 posts
Posted July 29, 2017 - 06:24 PM
I been shutting it off at different throttle positions and about 1/2 seems to be no bang. Here's a more recent pic new seat and front tires
  • MH81, Cvans and shorty have said thanks
#10 shorty ONLINE
shorty
  • 5,268 Thanks
  • 5,160 posts
Posted July 29, 2017 - 07:45 PM
Looking good.
