Wisconsin TRA 10D external resistor question
3 replies to this topic
#1 Joedogs73 OFFLINE
Joedogs73
  • 12 Thanks
  • 18 posts
Posted July 21, 2017 - 09:50 PM
The external ignition coil resistor is getting extremely hot when key is in ON position.
I have new ignition coil, resistor, ignition switch and points.
What could cause this?
Thanks
  • chieffan said thank you
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,819 Thanks
  • 2,411 posts
Posted July 21, 2017 - 10:44 PM
It is very common for a ballast resistor to get too hot to touch when the key is on, and the points are closed.
It will be hot while the engine is running, but not as hot as when the engine is not running with the points closed.
When the points are closed, you are connecting battery voltage to ground through the points.  ....The resistor will heat up like your toaster.
  • Bolens 1000, boyscout862, MolonLabe and 2 others have said thanks
#3 Joedogs73 OFFLINE
Joedogs73
  • 12 Thanks
  • 18 posts
Posted July 22, 2017 - 02:43 PM
Ok thanks .... Its ok to run it that way then? Should I just get a coil with an internal resistor?
#4 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,819 Thanks
  • 2,411 posts
Posted July 22, 2017 - 04:24 PM
It's OK to run it that way as long as the resistor is mounted where the heat will not affect anything nearby.
