1886-01 Flywheel Help
2 replies to this topic
#1 Husky OFFLINE
  • 1,277 Thanks
  • 1,123 posts
Posted July 20, 2017 - 11:58 AM
My 1886-01 if the label is correct:
Year 1971
Engine K482-s
s/n 2231706
spec 35113b
has what appears to be a 30 amp system. It's got the black regulator/rectifier with the heat sink. It is made by Synchro. I've heard that the 1886 had both  15 and 30 amp systems. My regulator/rectifier and stator is new as of a few years ago. I noticed a bad spot on my flywheel ring gear that the starter engages against.
I'm trying to find a replacement flywheel or perhaps just the ring gear if possible(easiest solution). I'm not sure if I  need a 30 amp specific flywheel? I can't find any part numbers that would indicate which flywheel would work for me.
Would anyone know if there is a difference between the flywheels off of a k432 in an 1886-01 vs 02-05 or and ht 20 etc? I'm hoping that I could simply swap out the ring gear. I see it listed separately in the k432 manual. Thank you for any help with this.
Edited by Husky, July 20, 2017 - 12:00 PM.
  • blackjackjakexxix and boyscout862 have said thanks
#2 boyscout862 OFFLINE
  • 13,191 Thanks
  • 9,279 posts
Posted July 20, 2017 - 01:19 PM
Check with our sponsors directly. They should be able to help you. Good Luck, Rick
#3 WrenchinOnIt OFFLINE
  • 3,620 Thanks
  • 976 posts
Posted July 20, 2017 - 04:36 PM
As far as swapping of flywheels you do need a 30amp specific for the k482 a k532 (ht20) will fit but you'd have to change over to a 15amp system, which I'd recommend if you hadn't already invested in a new rectifier/regulator and stator. The 30amp system over charges the battery and that's why you see all the '86's with the discolored paint down the frame rails and the drag link eaten away at from the battery acid. The ring gear off a k532 or 582 should work they all use the same starter. I'm thinking I have some k482 flywheels somewhere because I changed all my '86's over to the 15 amp charging systems , flywheels and all. Question is where did I put them , I'll give a look if your in a bind.
Edited by WrenchinOnIt, July 20, 2017 - 05:37 PM.
  • Bolens 1000, Husky, blackjackjakexxix and 1 other said thanks
