looking for carb or kit
8 replies to this topic
#1 cgp OFFLINE
cgp
  • 3 posts
Posted July 18, 2017 - 08:03 PM
I recently got an ole 5260 walk behind with an eight hp kohler. The carb is in bad shape. I was hoping to find a replacement or a kit. It's a Walbro ; WHL17-3287. I will try and post a pic or two.
Thanks alot
Cliff from Liberty
#2 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted July 19, 2017 - 02:50 AM
:wave: Welcome to the forum!
#3 Flattop OFFLINE
Flattop
  • 2 Thanks
  • 2 posts
Posted July 19, 2017 - 05:07 AM
Interested to see the carb. I have never seen a Walbro carb on a Kohler. In the late 70s I worked for a Gravely dealer and serviced many 5260's and 526's.
#4 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,984 Thanks
  • 9,629 posts
Posted July 19, 2017 - 06:48 AM
If you go on eBay, there are replacement carbs being sold. These are Chinese made and the quality is reflected in the price. Some are more expensive than others.
#5 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted July 19, 2017 - 08:59 AM
Should just take the regular WHL repair kit that gives you gaskets / needle and seat cost about $18.75 from me
  • EricFromPa said thank you
#6 cgp OFFLINE
cgp
  • 3 posts
Posted July 21, 2017 - 10:13 AM
Thanks for responding....I attached a couple of pics of the carb.
Gonna try and patch bottom of bowl (several pin holes)
with Permatex
Do yaw know if all the Walbro bowls are the same size?
 Can't seem to add pic
#7 Flattop OFFLINE
Flattop
  • 2 Thanks
  • 2 posts
Posted July 22, 2017 - 10:49 AM
Went through my old service info and found Kohler carb cross reference and KT17 KT19 service bulletin, uploaded them in the Kohler engine section, don't know if helpful to you or not.
  • KennyP and cgp have said thanks
#8 poncho62 ONLINE
poncho62
  • 1,606 Thanks
  • 1,613 posts
Posted July 22, 2017 - 06:52 PM
Not a Walbro, but I think this would work....... http://isavetractors...k160-k161-k181/
  • cgp said thank you
#9 Smedley OFFLINE
Smedley
  • 1 posts
Posted August 04, 2017 - 01:41 PM
Hi!  I've got a Gravely 5260 too and I need a new carb as well.  Throttle shaft all fouled up, broken off actuator arm and REAL sloppy in its bushing.  Whatever did you find out CGP?  I can't see any pictures that you might have attached of your carb if in fact they went through...
Thanks!
Jim
