JD 510 keeps blowing the PTO clutch Fuse
1 reply to this topic
#1 Python00 OFFLINE
Python00
  • 9 posts
Posted June 20, 2011 - 04:31 PM
Grandmother called and told me it keeps blowing the fuse, at first I was just thinking about buying a new clutch but after a little research it looks like it could be 2-3 things. I will check the wires and look for bare spots but what else should I look for?
#2 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted June 20, 2011 - 04:34 PM
You will want to check the resistance on the field coil. I don't know what the specific measurement is that you are looking for but hopefully someone will chime in. The other thing you can check too is that the switch isn't shorting out either.
