Need help Identifying what is mounted to the flywheel of my 1050
20 replies to this topic
#1 logmillingman OFFLINE
logmillingman
  • 597 Thanks
  • 318 posts
Posted July 14, 2017 - 07:31 PM
Hey Guys, I need some help to figure out what this is that is mounted to the flywheel on the Bolens 1050 Wisconsin motor.
#2 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted July 14, 2017 - 07:52 PM
Have no idea what that is
Not supposed to be there though!
  • logmillingman said thank you
#3 logmillingman OFFLINE
logmillingman
  • 597 Thanks
  • 318 posts
Posted July 14, 2017 - 08:26 PM
I have a feeling that what ever it was that some of it is now missing.
#4 LPBolens ONLINE
LPBolens
  • 1,415 Thanks
  • 971 posts
Posted July 14, 2017 - 08:57 PM
Maybe the engine came out of something like a Bush Hog or a Cub Cadet tractor that used a PTO clutch there?
#5 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,913 posts
Posted July 14, 2017 - 09:27 PM
I'ld say a clutch. Does that belt pulley mount to flywheel?  Was thinking that big knob in center maybe tightens up when you want the pulley to lock into engine??
Course, all this may be stuck now, with condition of rest of rig. Try oiling up some of that area and see if center turns, or arms wiggle or whatever.
#6 karel ONLINE
karel
  • 2,073 Thanks
  • 1,384 posts
Posted July 15, 2017 - 04:46 AM
That was a clutch!
#7 logmillingman OFFLINE
logmillingman
  • 597 Thanks
  • 318 posts
Posted July 15, 2017 - 08:24 AM
I think LPBolens is correct this engine is not the original engine it may be a donor out of another piece of equipment or tractor. The person may have stripped off what was in the way of the hood and left the rest. I agree with glgrumpy and Kalel that it makes sense that it would be a clutch, my friends Cub Cadet has a front mounted clutch to drive the attachments.
The ID plate is missing off the engine how would I determine the what size and series Wisconsin it is?
#8 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted July 15, 2017 - 09:21 AM
If the engine has a square points box on the side the carb goes on its likely a TR10D or TRA10D engine, in some freak instance where someone swapped carb manifolds it could be an S8D as well
#9 Lmiller3358 OFFLINE
Lmiller3358
  • 1,480 Thanks
  • 1,421 posts
Posted July 15, 2017 - 09:28 AM
Maybe electric start, what's that bracket hanging over the left front tire for ?
#10 logmillingman OFFLINE
logmillingman
  • 597 Thanks
  • 318 posts
Posted July 15, 2017 - 09:48 AM
Lmiller, that is the bracket for the starter generator, the drive belt goes around the big pulley on the flywheel
#11 logmillingman OFFLINE
logmillingman
  • 597 Thanks
  • 318 posts
Posted July 15, 2017 - 10:07 AM
Brian I went out and took a picture of the side of the engine.
Here is what it looks like.
Stephen
  • Cvans said thank you
#12 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted July 15, 2017 - 10:14 AM
I would say TR10D or TRA10D
Looking at the throttle linkage assembly on the shroud I think its safe to say the motor did not come from a Bolens originally
#13 logmillingman OFFLINE
logmillingman
  • 597 Thanks
  • 318 posts
Posted July 15, 2017 - 10:27 AM
Thanks Brian, do you know how long the crank shaft is supposed to be, I stuck my finger into the pulley and the shaft is a good ways in there. When I get ready to fix it up to get it running am I going to have to know which engine it is or is there some way to tell the difference?
As you can see there are parts missing that I will need to purchase for the Wisconsin.
Stephen
#14 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted July 15, 2017 - 10:30 AM
The cranks were not very long originally on the Bolens, really only way to tell the difference between the two is looking at the piston and rod, that was really the only difference between the two motors
#15 logmillingman OFFLINE
logmillingman
  • 597 Thanks
  • 318 posts
Posted July 15, 2017 - 10:44 AM
I am assuming I will not be able to tell what year the 1050 is because there is no ID tag on the tractor?
Did the 1050 come with different Wisconsin motors through the years of production?
When you say the piston and rod are different is it cosmetic or actual size difference?
Thanks again for your help!
Stephen
