Kohler fuel shut-off repair?
4 replies to this topic
#1 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted July 12, 2017 - 10:48 PM
On my single Courage, I mis-handled it getting it on the chassis I guess and broke the wire on the fuel shut-off.  Wire unplugs from one out of engine, but is short. Also, the wire is broken only about 1/2" from the selinoid. SO, can I solder that back together, or will it be too hot for coil or whatever is inside? I could use crimps, but thought solder would be better if I can work it that small. OR, other choice is just go buy another selinoid. I haven't checked on prices of those yet, but bet it'll scare ya.
#2 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted July 13, 2017 - 06:42 AM
Sounds like your talking about the fuel solenoids, I guess you could try and splice the wires back together and see if they work. All the solenoid does is move up to cut the fuel supply off if it works you should hear it click when the key is turned in the on position.
#3 chieffan OFFLINE
  • 11,368 Thanks
  • 7,116 posts
Posted July 13, 2017 - 07:18 AM
Using a pencil type solder iron tin the two wires first.  Soldering paste helps to clean the wires for better solder absorbent.  Then lay them together and blend the solder together.  Heat shrink on first of course. Good luck.
Edited by chieffan, July 13, 2017 - 07:19 AM.
#4 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,178 Thanks
  • 2,256 posts
Posted July 13, 2017 - 08:03 AM
I cut the end off of the plunger and installed an in-line shut off.     Rick
#5 abu507 ONLINE
abu507
  • 16 Thanks
  • 49 posts
Posted July 13, 2017 - 12:25 PM
Take plunger out put plug in hole use old gasket and forget about it
