Clinton questions
7 replies to this topic
#1 adamjd200 ONLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted July 12, 2017 - 01:29 PM
As I have almost 0 experience with clinton engines, I managed to get the one I've been working on to run, but it was surging, then evened out, but is running rich, that was where I stopped with it, could using. Form a gasket between carb and engine cause this, didn't have correct gasket on hand. Also what gear oil should I use in the gear reduction on this?
The engine info is:
Carburetor: Carter model N
Model#:87618761A0A C
Serial#:2494723
#2 My3kidsfather ONLINE
My3kidsfather
  • 19 Thanks
  • 20 posts
Posted July 12, 2017 - 03:05 PM
Do we really have to talk about Hillary?
  • HANKG said thank you
#3 adamjd200 ONLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted July 12, 2017 - 04:15 PM
Uh, I was talking about clinton engines, don't know where you're going with this?
#4 jimmy G ONLINE
jimmy G
  • 915 Thanks
  • 622 posts
Posted July 12, 2017 - 05:46 PM
The engine info is:
Serial#:2494723
I use straight 30# oil,if you had to run the jets in to get it to straighten out I'd check the needle seat,a bad float will do this also, catch the gas in a pan and look for junk in it and the float Bowl,these are good engine's and worth the effort
#5 jimmy G ONLINE
jimmy G
  • 915 Thanks
  • 622 posts
Posted July 12, 2017 - 06:11 PM
there is a learning curve to this site lol,No gun's, No religion and No politics, it's part of the charm
#6 adamjd200 ONLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted July 12, 2017 - 06:14 PM
Didn't bottom out the needles, did replace the float, if it was out of adjustment could this cause it to do this?
#7 jimmy G ONLINE
jimmy G
  • 915 Thanks
  • 622 posts
Posted July 12, 2017 - 07:13 PM
yes it could,set the float so it's level with the casting when it closes,up or down from this just a hair for fine tuning,lower is leaner,if the float is up past level to shut the gas off it could be the problem
#8 My3kidsfather ONLINE
My3kidsfather
  • 19 Thanks
  • 20 posts
Posted July 13, 2017 - 01:34 AM
Sorry I have a twisted sense of humour. Part of being a redneck inAlberta.
