4 speed problem
5 replies to this topic
#1 3wheeler OFFLINE
3wheeler
  • 2 posts
Posted July 11, 2017 - 05:23 PM
Hi, I am a new owner of a 1614 Power King. It has the 4 speed tranny. Serial # 60106. The transmission is stuck in second. If I move the shifter it seems to jam into 2 gears at once because it won't move and just stalls the engine. I have found a lot of info on the 3 speed and how to repair them but I'm coming up short on any info for the 4 speed. Can someone steer me in the right direction? Thanks
#2 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted July 11, 2017 - 08:28 PM
  No experience with a PK, but it sounds like the shift fork for 2nd has slipped off the gear collar.
                                               Mike
#3 MNGB OFFLINE
MNGB
  • 2,139 Thanks
  • 1,417 posts
Posted July 11, 2017 - 08:57 PM
Hi threewheeler, welcome to the group and to PK ownership, I have a PK with the 4 speed trans but fortunately have had no problems so I don't know what could be the problem I'll attach a 4 speed manual maybe it will of some help to you there should other that will see your post and maybe able to help.
Attached File  1982 4-speed transmission.pdf   793.92KB   47 downloads
#4 glgrumpy OFFLINE
  • 8,623 Thanks
  • 7,926 posts
Posted July 11, 2017 - 10:42 PM
This is metal tractor or later Plastic Body one?  Plastic ones have problems with clutch paks alot and can mess up front shaft bearings and then cause things to not align and etc. LOTS of bearings in those newer 4 spds.
#5 abu507 OFFLINE
abu507
  • 11 Thanks
  • 37 posts
Posted July 12, 2017 - 08:25 AM
Sent Message
#6 3wheeler OFFLINE
3wheeler
  • 2 posts
Posted July 13, 2017 - 07:29 PM
Mine is the metal body
