G11Xl Engine Manual
3 replies to this topic
#1 chieffan ONLINE
  • 10,201 Thanks
  • 6,662 posts
Posted July 11, 2017 - 05:03 PM
This is kind of a different B&S engine set up.  11 hp Horizontal shaft, Type: 03101; Model 253417.  Trying to locate the correct manual so I can get the float set right.  Manuals I found were for either older or newer engines.  Anyone have any ideas?
#2 glgrumpy OFFLINE
  • 8,623 Thanks
  • 7,926 posts
Posted July 11, 2017 - 05:40 PM
Old teleflow or newer carb? These say invert and be level with gskt surface. I like to set them lower, most leak or change needs at stock setting. If not this kind.....NEVER MIND!
  • chieffan said thank you
#3 Bolens 1000 ONLINE
  • 14,989 Thanks
  • 18,141 posts
Posted July 11, 2017 - 06:49 PM
You will want the antique repair manual for engines 1980 and older , its uploaded in the files here
Hard copy from B&S is about $65 so I stopped stocking them!
#4 chieffan ONLINE
  • 10,201 Thanks
  • 6,662 posts
Posted July 12, 2017 - 07:41 AM
Thanks Brian.  Have that manual and missed the style of carb on this one first time around.  Did find it now and have the float adjusted according to specs.  Was a tiny crack in it I soldered shut but may not have got it all.  Will know later today when I get it off again.  Always easier the second time around.
