GK question
7 replies to this topic
#1 Luigi OFFLINE
Luigi
  • 17 Thanks
  • 15 posts
Posted July 11, 2017 - 11:09 AM
  Hi everyone, my first post here. My Grounds Keeper leaks gear lube from the differential where the axle housing bolts to it. It looks like there is a oil seal in the diff case that I'm guessing is the problem but I can't find a source for the part (1718797).
  Any ideas on fixing this?
  • blackjackjakexxix and logmillingman have said thanks
#2 dtsh OFFLINE
dtsh
  • 234 Thanks
  • 159 posts
Posted July 11, 2017 - 01:02 PM
I would reach out to one of the vendors here.
If they can't get what you need, you might try taking measurements of the old seal and seeing if you can cross reference a match at your local auto supply.
Edited by dtsh, July 11, 2017 - 01:04 PM.
  • boyscout862, logmillingman and Luigi have said thanks
#3 framesteer ONLINE
framesteer
  • 423 Thanks
  • 202 posts
Posted July 11, 2017 - 01:15 PM
Try to determine the manufacturer's part number on the face of the seal.  If you can't see that, measure the shaft diameter and seal bore diameter, along with the depth of the seal metal housing.  Either case, take the part number or the measurements to a NAPA store or an industrial bearing supply company and they should be able to find a replacement.
  • MailmAn, logmillingman and Luigi have said thanks
#4 Luigi OFFLINE
Luigi
  • 17 Thanks
  • 15 posts
Posted July 11, 2017 - 03:07 PM
Thanks, dtsh and framesteer for the help.
#5 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted July 11, 2017 - 06:52 PM
Unfortunately I do not have this seal in my system
I'd take it to a local bearing / seal house if you have one
  • logmillingman said thank you
#6 boyscout862 ONLINE
  • 12,860 Thanks
  • 9,174 posts
Posted July 12, 2017 - 11:38 AM
Welcome to GTT. Check out our Manuals Section for info that you want. Good Luck, Rick
#7 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 2,937 Thanks
  • 2,103 posts
Posted July 12, 2017 - 04:18 PM
Welcome aboard,those GK's are are pretty neat machines and a blast to drive,unfortunately i also dont have that one in stock,post some pics of the machine when you get time
#8 Luigi OFFLINE
Luigi
  • 17 Thanks
  • 15 posts
Posted August 21, 2017 - 06:59 PM
Thanks for the welcome and advise. I did download the manual, and after looking at it for a long time I wondered if the gear lube was just seeping past the bolt threads. So, I removed the bolts one at a time and put Teflon sealer on them. No more leak! :dancingbanana:
 Thanks again for the replies,
 Jim
  • blackjackjakexxix, KennyP, MailmAn and 1 other said thanks
