Mower Blades
2 replies to this topic
#1 bosbar OFFLINE
bosbar
  • 19 Thanks
  • 13 posts
Posted July 10, 2017 - 08:14 AM
I have a 2006 JD 2305 with a 54" mulching deck. I have been removing and installing the blades with a impact wrench for 11 years, no problem.
Yesterday, after sharpening the blades, I was hammering the bolts as usual and stripped them out. I guess after 11 years, they just couldn't take it anymore. I guess that's why the manual says to torque them down to 50 ft.lbs.
Well instead of spending $72.00 each for new spindles, I retapped each one with a 1/2 x 20 tap.
Worked out great and saved me some money.
Long story short, go easy on the impact wrench.
#2 dropped82 ONLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted July 10, 2017 - 08:23 AM
It's not hard to do with an impact. Glad you were able to repair instead of the expensive replacement. I use an impact to remove but tighten by hand. My blades don't need to 750lbs of torque my impact can deliver.
#3 chieffan ONLINE
  • 10,177 Thanks
  • 6,651 posts
Posted July 10, 2017 - 12:39 PM
I use a battery impact.  No hose to drag around, tightens them tight enough to stay on.  Don't deliver near what an air impact will.  Be a good idea to change those bolts every couple years anyway.
Edited by chieffan, July 10, 2017 - 12:39 PM.
  • dropped82 said thank you
