What oil to replace type f?
11 replies to this topic
#1 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted July 09, 2017 - 03:27 PM
Sunstar rear in Sun Star says type F. What tractor fluid should I get? F is old s hool, harder to find too.
  • Jazz said thank you
#2 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted July 09, 2017 - 03:36 PM
You can get type F anywhere, even @ Wally World!!!
Or, the napa brand universal Hy-Tran is good stuff, but more expensive.
Edited by stiemmy, July 09, 2017 - 03:41 PM.
#3 chieffan ONLINE
  • 10,158 Thanks
  • 6,642 posts
Posted July 09, 2017 - 03:55 PM
Use a brand name you can get locally and use Hi-Tran, Transdraulic, or whatever name that company has for it.  I use Northland brand as a local repair shop has carried it for years in everything from 2 gal jugs up to & including the 250 gal mini bulk tanks.  Lot of the bigger farmers use the mini bulks, set up by Northland.  Transdraulic on top and diesel oil on the bottom.
Edited by chieffan, July 09, 2017 - 03:56 PM.
#4 dodge trucker ONLINE
dodge trucker
  • 2,436 Thanks
  • 3,126 posts
Posted July 09, 2017 - 05:30 PM
I had a Sears SS12Hydro once and I remember it said to use Type F and "nothing else"  but there are things out now that were not available then.... IDK what brand of hydro that thing had in it too long ago.
My Woods 1250 ZTR suggests Woods hydraulic oil but at $35 a quart no way....  it has Eaton 700 series hydros  as I remember I used ATF... more specifically I put Dexron in it when I did a flush... I read somewhere that was what was recommended, I don't remember if it was Wheel Horse or who but it was another manufacturer that ran the Eaton 700....
#5 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted July 09, 2017 - 05:55 PM
Well, bought generic Mile Master 303 Hydraulic Fluid.  Says for 70's and older equipment mostly.  My thoughts are if it has OIL in it, it will work, anything!  They had Shell Rotella on sale in 2 gals, bought out, I would have gotten that, like the oils.   It was $29 but the % gal was $65, too much. Only need 6qts.  One I bought was 5 Gallon and $29, so will see what happens. Didn't get filter yet, no catalog to look up, haven't got old off, manual does not say what number, just flow rate and NO anti-flo backfill was needed.  So, will pull that later and check auto store here. To drain have to pull a big hose. What was wrong with a plug, sheesh!
#6 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted July 09, 2017 - 06:25 PM
As i recall it went type A- type F- Dexron 2/3...
#7 Cvans ONLINE
  • 6,648 Thanks
  • 6,129 posts
Posted July 09, 2017 - 08:39 PM
I use Type F as it is and stays thinner than Hy-Tran in cold temperatures making it easier on the hydro when it's cold. Don't like listening to a growling hydro when it is below freezing outside.  :(
Edited by Cvans, July 09, 2017 - 08:39 PM.
  • Oldford said thank you
#8 olcowhand ONLINE
  • 41,173 Thanks
  • 31,426 posts
Posted July 09, 2017 - 09:22 PM
Dexron III is what I use unless the hydro is worn, then I use either 303 hytran or 30wt motor oil.
  • Cvans and Oldford have said thanks
#9 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted July 10, 2017 - 06:25 AM
That has a Sundstrand pump and peerless axle. I run either 15w40 or hytran. It seems pretty flexible on what fluid. All machines i own have the same pump. Some inline and some U style. You have the U style like Deeres. This Deere has hytran from Napa. That's what Deere calls for although I don't think it matters. My Masseys all have 15w40 rotella in them. I used that after advice from Olcowhand. Also, here's the Napa filter needed.
Edited by dropped82, July 10, 2017 - 12:40 PM.
  • olcowhand, Cvans and Oldford have said thanks
#10 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted July 10, 2017 - 05:49 PM
Well, went and spent more $$ on the Real F trans oil. Darn stuff was over $5 each and the NEWER Dex/Merc stuff the guy said should work was only $3.99 each.  Got a filter over to the Mower shop, looks good. There was even a couple of those used, had to have tractor model numbers to get right one, sheesh!  I pulled the old, nothing written on it or stamped. Looks like might have been orig, sure been long time at least. Work on it later, tractor show this week.  Winamac, IN.  Now looking at weather and asking around site, not looking good for flooding issues and such. Hope it even stays going, was canceled one year with flooding. River wraps right around the park it is in.
#11 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted July 11, 2017 - 11:22 PM
Took canopy to park today and set it up, weather wasn't bad, but better as we were leaving, thanks, ha!  At home went out and drained the hydro trans on the Sun Star. Mine had plug in bottom, the later manual I had, the show removing big hose. I like the plug much better. Anyway, got out almost 5 qts. I measured it. Capacity is 6, so not too bad. WAS pretty dark, think dirty  too, looking at things in the containers I was measuring with. Last bit out was little greyer and thicker, maybe that is metal bits?  Didn't really seem like I've seen on car xmissions, so maybe just sludge. I put 5 qts back in and started, and turned wheels and raised lift and worked it a bit to get traveling in there. Seemed fine. I then put in that last qt, and looked at the tube on back and it seemed about what manual said should be, so good to go. I then took it out and ran around yard both directions, F and R I mean. Then took it wide open down my road and back and all is nice. I'm gonna like this one. Found paint I'm gonna try on it, see my other posts for that info. Will be a Mean Green Machine soon!
  • MH81, KennyP and Cvans have said thanks
#12 foundryratjim OFFLINE
foundryratjim
  • 7 Thanks
  • 7 posts
Posted July 28, 2017 - 10:22 AM
I use amsoil super shift in my stuff instead of type f.
Sent from my Pixel using Tapatalk
