h16xl engine problem
5 replies to this topic
#1 bigshelly478 OFFLINE
bigshelly478
  • 2 Thanks
  • 8 posts
Posted July 07, 2017 - 07:23 PM
I was mowing my lawn today with my H16xl.  Everything was running smooth except for anytime I went down hill.  When I went down hill the oh160 engine would sputter, smoke and at times almost die.  It would then go back to normal operating when I was on flat ground or going up hill.  Any ideas?
-Ben
  • chieffan said thank you
#2 Cnc ONLINE
Cnc
  • 32 Thanks
  • 22 posts
Posted July 07, 2017 - 08:45 PM
What colour was the smoke, blue? Maybe overfilled crank case?? Or depending on the orientation of the carb maybe a slightly too high of float level that floods the carb body a bit when the tractor is pointed down hill. I don't have a HH160 but I do have a HH120 in a Massy so I am just throwing ideas out there.
  • Bolens 1000 and chieffan have said thanks
#3 chieffan ONLINE
  • 8,368 Thanks
  • 5,790 posts
Posted July 08, 2017 - 07:26 AM
I agree with cnc.  First guess would be fuel - flooding out going down hill.  Float level set a bit high?  If oil level is OK, then look at the float setting.
#4 nsengineer OFFLINE
nsengineer
  • 49 Thanks
  • 41 posts
Posted July 08, 2017 - 08:49 AM
Like above answers float level setting but also check in tank for some possible debris covering up fuel intake hole.  The hole is at the front of the tank.
#5 chieffan ONLINE
  • 8,368 Thanks
  • 5,790 posts
Posted July 08, 2017 - 01:06 PM
Water settles to the bottom, moves forward going down hill?  Shouldn't make it smoke though, just run crappy.
#6 bigshelly478 OFFLINE
bigshelly478
  • 2 Thanks
  • 8 posts
Posted July 08, 2017 - 05:49 PM
I adjusted the float and have had no other problems going up and down the hill when I tested!  Thanks for the tips!!
Edited by bigshelly478, July 08, 2017 - 05:49 PM.
