Neighbors Generator
23 replies to this topic
#16 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,505 Thanks
  • 6,161 posts
Posted July 18, 2017 - 05:52 AM
Make sure mice haven't plugged the cooling passages..  Read the plug..  If it's white I'd replace the fuel line (could be collapsing) and check the cap vent..  Just a few ideas
  • KennyP, Sawdust and Mark 149 J. have said thanks
#17 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 18, 2017 - 05:59 AM
I've had the cap off and it still did it. Head fins are not enclosed in tin, they are clean. I had forgotten about the infrared thermometer i bought a while back. I can use it to see where most of the heat is.
  • Sawdust and Mark 149 J. have said thanks
#18 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 18, 2017 - 09:35 AM
I took the thermometer out and got some pics. First pic is how it was ran before. Right next to that black holder in the middle, I got 170° after about 15 minutes and the air bubble in the filter was growing.
There is another hole the holder would bolt to, so I moved it there and got some clearance from the head fins.
I'll see what this does and report back.
  • boyscout862, Sawdust and Mark 149 J. have said thanks
#19 Sawdust ONLINE
Sawdust
  • 6,217 Thanks
  • 3,581 posts
Posted July 18, 2017 - 09:44 AM
Can you take that black connector off & let the fuel line hang. It looks like it's coated but being metal maybe it's still disapating some heat in the fuel line.
  • KennyP and Mark 149 J. have said thanks
#20 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 18, 2017 - 10:29 AM
Moving it over helped. Highest temp I got this time was 120°. Now I'm thinking maybe the filter isn't letting enough fuel through. I can take it out and put in a connector, but that would drop the ID down to 1/8". Guess I can try it. I'm not even sure the unit came with a filter as it has the worm drive clamps on it. I have not found a manual for this with a Subaru engine on it. Only Honda.
#21 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 18, 2017 - 11:10 AM
Success! I checked the ID of the hose connector and it's 3/16". Put it in place of the filter and it ran for 30 minutes without a hickup. :dancingbanana:
I'm going to see if Atwoods has a Kohler filter for a twin cylinder, that should let enough fuel through for this thing.
  • boyscout862, Sawdust, Mark 149 J. and 1 other said thanks
#22 Sawdust ONLINE
Sawdust
  • 6,217 Thanks
  • 3,581 posts
Posted July 18, 2017 - 12:31 PM
Kenny I buy these in bulk they come in different sizes & have graduated nipples that can be cut off.
http://www.ebay.com/...ydWkXYg&vxp=mtr
#23 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 18, 2017 - 12:34 PM
Yeah! Would be nice if I had them on hand. The one I put on there was similar, just didn't let enough fuel through for this engine. And I bought a larger one than what was on it before!
  • boyscout862 and Sawdust have said thanks
#24 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 19, 2017 - 10:10 AM
I tried another filter like the ones in Sawdust's post and it sucked it dry too. I can't find any filters for the larger engines as yet. May have to go to the mower shop to get one.
