Gas gauge for opaque tank
8 replies to this topic
#1 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted July 03, 2017 - 04:23 PM
  Since the Dixon tank is black plastic I've always had a piece of dowel rod aboard to stick in the tank. I came up with this idea: put a tee in the gas line and run the clear hose up by the neck. Clamp to the neck with a ziptie  and stick some cotton ball in the end to keep out foreign objects.
                                                 Mike
  • Gtractor, Alc, Texas Deere and Horse and 4 others have said thanks
#2 dthomp17 ONLINE
dthomp17
  • 605 Thanks
  • 482 posts
Posted July 03, 2017 - 05:26 PM
I like it.  Is that clear tubing regular gas line or something else?  Trying to think of any problems you might run into If your gas cap vent hole gets plugged.
  • boyscout862 and ol' stonebreaker have said thanks
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,270 Thanks
  • 10,114 posts
Posted July 03, 2017 - 05:29 PM
You're low on fuel.
#4 boyscout862 ONLINE
  • 13,442 Thanks
  • 9,391 posts
Posted July 03, 2017 - 08:49 PM
It is a clever idea. I just worry that it may get snagged by something as you go by. Can you tape it to the tank with a clear tape? Good Luck, Rick
  • dthomp17, ol' stonebreaker and Bob E have said thanks
#5 Cvans ONLINE
  • 7,112 Thanks
  • 6,302 posts
Posted July 03, 2017 - 10:30 PM
Looks like a good solution as long as it doesn't set outside in the rain.  :thumbs:
#6 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted July 04, 2017 - 09:27 AM
Great idea Mike. You could always drill a hole in the top of the neck and mount/glue a 90° fitting to return the hose back into the tank.
  • Cvans, ol' stonebreaker and Bob E have said thanks
#7 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted July 04, 2017 - 03:52 PM
  That's a good idea, TD&H!! I could drill and tap a 1/8" NPT hole in the neck and install a brass 1/8" sreet ell with a hose barb screwed into it. The clear hose isn't fuel hose so it will eventually get stiff and possibly crack. In the meantime I'll see if I can locate some clear fuel hose. Our local auto supplies might have some.
                                            Mike
  • Texas Deere and Horse and Cvans have said thanks
#8 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted July 05, 2017 - 08:49 AM
Molotov Cocktail.
#9 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted July 05, 2017 - 07:56 PM
   Thanks, TD&H, for the suggestion!! Drilled and tapped a 1/8" NPT hole in the neck toward the back of the neck to prevent a snag, installed a brass street ell with a hose barb, trimmed the hose to length. Looks a lot better that way and safer too.
                                                  Mike
  • Cvans said thank you
