Found
Wisconsin Engine S14D
electrical ignition parts
5 replies to this topic
#1 Harleyguy70 OFFLINE
Harleyguy70
  • 20 Thanks
  • 16 posts
Posted July 03, 2017 - 08:59 AM
Need the stator that goes under the flywheel in the magnetic ring and the Ignition module.  Both burned up.
  • chieffan said thank you
#2 DZG OFFLINE
DZG
  • 607 Thanks
  • 525 posts
Posted July 03, 2017 - 09:12 AM
I got an S12D, ill sell the whole thing cheap if ya can use it. Was told (by my uncle) it ran when pulled
  • chieffan and Harleyguy70 have said thanks
#3 chieffan OFFLINE
  • 9,569 Thanks
  • 6,407 posts
Posted July 03, 2017 - 09:47 AM
My experience with an S14D with ignition problems was very expensive and never did get spark.  Good engines when they run - but when they loose spark, replace the engine.  Cheaper and much less frustrating.
  • Harleyguy70 said thank you
#4 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted July 03, 2017 - 10:49 AM
Have you tried Dr Bolens he is the resident Wisconsin guy
http://gardentractor...parts-supplies/
very knowledgeable and helpful
#5 EricFromPa ONLINE
EricFromPa
  • 3,519 Thanks
  • 3,067 posts
Posted July 03, 2017 - 01:18 PM
If Brian doesn't have parts this may work. This is interesting. S12D powered generator $99 OBO in Davison, Michigan. Looks like solid state ignition on it.
http://www.ebay.com/...QkAAOSwuLZY3p-h
Would parts off of work on your S14D?
Edited by EricFromPa, July 03, 2017 - 01:19 PM.
#6 Harleyguy70 OFFLINE
Harleyguy70
  • 20 Thanks
  • 16 posts
Posted July 03, 2017 - 01:40 PM
Problem solved.  Sam's Bolens in Crown Point, In  ordered me the upgraded replacement.  Thanks all
  • EricFromPa and KennyP have said thanks
Also tagged with one or more of these keywords: Found, electrical, ignition parts
