Clinton engine spark plug?
3 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted June 28, 2017 - 09:12 PM
I'm currently working on a Clinton engine on one of my Walk behinds, not too familiar with these, Carter model N is soaking in seafoam, gas tank is being cleaned prior to soldering a piece back on, and was completely dry, hadn't seen gas in years, what spark plug would be best in this, currently has a Auto lite A7 in it currently, which crosses to a j8c which I have, just want to make sure I have the right plug in it.
Numbers on the tag are:
Model:8761A0A C
Serial: 2494723
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted June 29, 2017 - 08:09 AM
Your plug is OK.
The Clinton takes a 14mm x 3/8" reach plug.
Autolite A7, Autolite A9, Champion J-8, J-11, CJ-8, J-8c are all OK.
  • Bolens 1000 said thank you
#3 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted June 29, 2017 - 09:40 AM
Thanks
#4 James Bosma OFFLINE
James Bosma
  • 1,331 Thanks
  • 656 posts
Posted June 29, 2017 - 06:11 PM
Most old small engines will use the Champion J8 series spark plugs
or any 14mm x 3/8 plug with the right heat range
