Bolens LF grader blade install questions
2 replies to this topic
#1 stiemmy ONLINE
stiemmy
  • 2,452 Thanks
  • 1,796 posts
Posted June 26, 2017 - 10:03 PM
Ok, so I layed this thing out to mount it, and something doesn't add up.
The rear mounting tabs on the frame are at 14 3/16" C to C.
They are about an 1" short of the insides of the rear axle 3 point brackets, and too wide for the 1050.
What gives? Do I need longer pins, or is this mounting bracket for something else (Tactor brand/model)?
The front will obviously work with the brackets avaliable adjustability.
Anyone have pics of thiers mounted at the brackets, and such???
Edited by stiemmy, June 26, 2017 - 10:08 PM.
#2 Rainier OFFLINE
Rainier
  • 437 Thanks
  • 441 posts
Posted June 27, 2017 - 12:02 AM
That does not look factory. With some fabrication you should be able to make it work. Hopefully some one with a factory one will post some pics to confirm.
  • stiemmy and Scottfleming1999 have said thanks
#3 stiemmy ONLINE
stiemmy
  • 2,452 Thanks
  • 1,796 posts
Posted June 27, 2017 - 12:25 AM
It has been confirmed on another post as factory, BUT, is it for a LF?? ;)
And how the hell does it mount on the back end?? Lol
If it's not for a LF, Id rather sell it, then degrade it by modding it, as someone else would appreciate that with the correct tractor to use it:)
Edited by stiemmy, June 27, 2017 - 12:28 AM.
