Fork Lift Build
jd f725 wheel chair lift
63 replies to this topic
#31 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 01, 2017 - 05:04 AM
Kenny, does the small solenoid wire back to the motor for power down?
No, it doesn't.
#32 TomLGT195 OFFLINE
TomLGT195
  • 3,274 Thanks
  • 2,531 posts
Posted July 01, 2017 - 06:22 AM
Kenny , what do you think the lifting capacity will be ? Are you hoping to lift whole tractors ? or just big bulky parts????
  • KennyP and Mark 149 J. have said thanks
#33 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 01, 2017 - 06:44 AM
Big bulky stuff! I doubt it will lift a full tractor.
  • TomLGT195 and Mark 149 J. have said thanks
#34 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 01, 2017 - 12:28 PM
Been playing with it more. Had to step back a bit and get the lower arms coming out straight. Have them set right . Made a brace to go between the two upper mounts, just to stiffen things a bit.
Got two braces per side coming down now. Had to put a small offset in them to keep the lowers arms straight. Will be cleaning things up for tack welds, then I can concentrate on going up for the mount.
  • olcowhand and WrenchinOnIt have said thanks
#35 UncleWillie ONLINE
  • 14,597 Thanks
  • 8,324 posts
Posted July 01, 2017 - 01:46 PM
Looks like you are getting a grip on how things will go together.
#36 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 01, 2017 - 03:38 PM
Slowly! This thing will mount real high and that bothers me!
#37 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 02, 2017 - 01:04 PM
I decided it was time to confirm the amount of lift this will have. It's a bit shy of what I thought, 27". Oh well, it's better that nothing! As soon as I round up some help, I will separate the lift to make easier for me to work with. That may be a challenge today!
  • olcowhand and Mark 149 J. have said thanks
#38 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 02, 2017 - 03:40 PM
I separated the wheel chair lift so I can delete the unnecessary items. Also make it easier to build the mount to fit. That one section was top heavy and about all I wanted for the day!
  • WrenchinOnIt, TomLGT195 and 29 Chev have said thanks
#39 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 03, 2017 - 04:15 PM
A special welcome  :wave:  here to member GeorgeT who posted a while back. He's my buddy from the tractor shows around here!
I got a bit more done today! The upper part of the mount is together. I'll marry those tomorrow.
  • olcowhand, MH81, WrenchinOnIt and 2 others have said thanks
#40 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 05, 2017 - 10:46 AM
Well, I clamped the parts together and set the lift frame on for a photo op. See what you think.
  • MH81, WrenchinOnIt, UncleWillie and 2 others have said thanks
#41 UncleWillie ONLINE
  • 14,597 Thanks
  • 8,324 posts
Posted July 05, 2017 - 12:49 PM
Mobile goal posts?
  • KennyP and MiCarl have said thanks
#42 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 05, 2017 - 04:29 PM
Mobile goal posts?
You got it Willie! See if you can score against me!
  • UncleWillie said thank you
#43 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 05, 2017 - 04:43 PM
Daniel, I tore this down and welded every spot weld up solid!
#44 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 06, 2017 - 02:00 PM
Got some quality time in so far today! Mounted the mast holder.
Then I removed the wheelchair roll-on ramp from the mast.
Then I mounted the pump back on the mast.
Finally, I attached the mast so I can get some angles figured out.
It's coming along slowly! Lots to figure out yet!
  • MFDAC, TomLGT195 and Mark 149 J. have said thanks
#45 KennyP ONLINE
  • 34,265 Thanks
  • 43,390 posts
Posted July 07, 2017 - 04:03 PM
Got some more done today! Made a pin location to take the place of the fold out, also hold the mast in the right position.
Here's a side shot of what I have so far.
Went to the rear to see about my 'ROPS'. Found the seat in the way of the mounts I made earlier. Oh well, a bit more 4 X 4  angle fixed that.
Got one vertical going up.
And both on!
  • MH81, MFDAC, UncleWillie and 3 others have said thanks
