Fork Lift Build
jd f725 wheel chair lift
63 replies to this topic
#16 secondtry OFFLINE
secondtry
  • 1,277 Thanks
  • 1,041 posts
Posted June 28, 2017 - 01:02 AM
Apparently the small solenoid controls nothing.  Pulls voltage directly from the battery thru the down switch thru the small solenoid to ground but accomplishes nothing. Don
#17 Alc OFFLINE
  • 6,437 Thanks
  • 7,241 posts
Posted June 28, 2017 - 05:14 AM
Could the small solenoid be used to dump the pressure to lower the lift ?
#18 KennyP OFFLINE
  • 35,122 Thanks
  • 44,131 posts
Posted June 28, 2017 - 05:50 AM
I think you're missing 12v to the red wire.
Can you post a pic of the small solenoid and what it's mounted to?
Yes it needs 12V, but hooking it in with the White wire causes the pump to raise the lift.
See Alc's reply below.
Here's some pics of the wiring.
The solenoid is in this pic. It doesn't seem to be working right now, plunger is, but I think the coil is bad. Will check some more today.
  • Mark 149 J. said thank you
#19 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted June 28, 2017 - 06:22 AM
All is right. That's how our box truck lift is.
Looks like Red to either batt plus or the large blue wire stud at the big solenoid.
Edited by MH81, June 28, 2017 - 06:25 AM.
#20 KennyP OFFLINE
  • 35,122 Thanks
  • 44,131 posts
Posted June 28, 2017 - 06:30 AM
I did start making a mount for it to sit on. Found some 1/4" X 2" angle and drilled it to match the existing holes.
Had some 1/4" X 2.5" angle and cut them to fit between the 2" pieces. Had to trim the corners off so they fit down flat.
Here I have it rigged up on a table about 27" tall. It will go to the ground, so I'm thinking it will raise about 30" total. High enough to put something in a pickup or on the table.
I'll have to mount it a lot more solid to find how much it will lift, this just works for testing! I have my suitcase weights (160 lbs. total) on the back side for counterweight on the table.
  • Alc, WrenchinOnIt, TomLGT195 and 1 other said thanks
#21 KennyP OFFLINE
  • 35,122 Thanks
  • 44,131 posts
Posted June 28, 2017 - 08:40 AM
I have confirmed that the solenoid is working, just need the red wire for it hooked directly to the incoming 12V source( cable side of solenoid). I'll need a long cable to run from the battery to this solenoid. Now to get the deck/lift off the the F725 so I can start making a mount for it. I will install a ROPS of a sort to use as an upper brace for the main frame!
#22 secondtry OFFLINE
secondtry
  • 1,277 Thanks
  • 1,041 posts
Posted June 28, 2017 - 10:30 AM
   The wiring diagram posted shows a solenoid control circuit only. No controlled circuit. As drawn in the diagram it could be an actuator mechanically controlling a valve, As I understand a solenoid it is an electrically activated switch. You have a coil in one circuit  which when energized closes a switch in another circuit. The diagram shows the coil "control" circuit but not the switch "controlled" circuit It seams to be an incomplete diagram. Don
#23 KennyP OFFLINE
  • 35,122 Thanks
  • 44,131 posts
Posted June 28, 2017 - 12:52 PM
That's how it is wired, Don. The red wire from the solenoid has to go to the 12V cable for it to work at all correctly. I haven't a clue why they did it this way.
The dissection begins.
Got the lift parts out of the way.
As things are right now, my mount height is 30" up. Not liking that, as that will cantilever the back end into the air. So I will 'adjust' the lift for this and make the mount much lower. Gonna take some contemplation.
#24 KennyP OFFLINE
  • 35,122 Thanks
  • 44,131 posts
Posted June 28, 2017 - 02:57 PM
If anybody out here has the smarts, what metric bolt is in between a 7/16" and 1/2"? The 7/16" is loose in the threads, 1/2" won't start in them. This is 'coarse' threads, like metric gives a ****.
#25 dtsh OFFLINE
dtsh
  • 221 Thanks
  • 143 posts
Posted June 28, 2017 - 03:03 PM
This would imply 12mm
Metric cares very much and is probably crying in it's room, meanie.  :D
Edited by dtsh, June 28, 2017 - 03:05 PM.
#26 KennyP OFFLINE
  • 35,122 Thanks
  • 44,131 posts
Posted June 28, 2017 - 03:17 PM
I hope it has a good cry, cause they suck to me! How you figure what size bolt in that mess is beyond me and I will not try to understand it!!!!!!
#27 KennyP OFFLINE
  • 35,122 Thanks
  • 44,131 posts
Posted June 28, 2017 - 05:35 PM
If I 'offended' anyone, didn't mean to! But I learned inches and fractions nigh on to 65 years ago! Never seen anything to help me learn the metric crap! Just seems like it's something else the government is trying to force me into! Now my political triad is over!
#28 KennyP OFFLINE
  • 35,122 Thanks
  • 44,131 posts
Posted June 30, 2017 - 04:49 PM
Finally found something suitable for the lower arms today. Some 1.5" X 1.5" square tube. Made some hangers and welded that all together.
Put them on.
Turned my attention to the upper hangers! Made some pieces to mount under here.
Throwed a jack under the front and looked things over.
Decided I needed to get the machine to an acceptable level all directions since I am working on gravel here.
Think this will work!
  • Alc, CRFarnsworth, WrenchinOnIt and 2 others have said thanks
#29 GeorgeT OFFLINE
GeorgeT
  • 2 Thanks
  • 2 posts
Posted June 30, 2017 - 08:24 PM
Kenny, does the small solenoid wire back to the motor for power down?
#30 secondtry OFFLINE
secondtry
  • 1,277 Thanks
  • 1,041 posts
Posted July 01, 2017 - 12:05 AM
9/16 tap Don
