Fork Lift Build
jd f725 wheel chair lift
63 replies to this topic
#1 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted June 26, 2017 - 07:46 AM
Well, the time has come to start this build. May not go very fast to start with, just brought the wheel chair lift back up yesterday. Gotta get it functioning again. I put the new belt on the F725 mower and the worn pulleys are eating it right up. Plust one of the PTO drive belts is about to give out. The lift valve needs rebuilt (if that is possible). Just more issues (and dollars) than I want to fool with. So the deck comes off and the lift gets fitted up to it.
Here's the link to the wheel chair lift thread I made some time back.
  • hamman, SupplySergeant and Mark 149 J. have said thanks
#2 chieffan OFFLINE
  • 8,799 Thanks
  • 6,034 posts
Posted June 26, 2017 - 09:11 AM
Some times we just have to let go of the things we like when the parts out value the equipment.  When I get my White with the 3 point back running good again looking at a fork lift/carry all for on the 3 point.  Will be watching your post.  My F525 did not have a deck raising feature until I hooked a post mounted winch to the front roller.
  • hamman said thank you
#3 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted June 26, 2017 - 04:18 PM
Count this thread as null and void as the hydraulics on the lift are trash!
  • boyscout862 and Mark 149 J. have said thanks
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,145 Thanks
  • 9,624 posts
Posted June 26, 2017 - 05:51 PM
Son of a .....
I want to see a homemade forklift!
  • KennyP and secondtry have said thanks
#5 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted June 26, 2017 - 06:45 PM
Son of a .....
  • KennyP, boyscout862 and Oldford have said thanks
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,145 Thanks
  • 9,624 posts
Posted June 26, 2017 - 10:07 PM
How about one of these?
  • MH81, KennyP and Mark 149 J. have said thanks
#7 Alc OFFLINE
  • 6,431 Thanks
  • 7,236 posts
Posted June 27, 2017 - 05:26 AM
Kenny , I've been reading your threads for a few years and can't believe your giving up so soon ?   What's wrong with the hydraulics on the lift ?
  • KennyP, Oldford and Mark 149 J. have said thanks
#8 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted June 27, 2017 - 05:43 AM
Al, everything I have tried to do lately has went South. But I've been thinking about this. The pump won't lift it but will hold it until I let go of the button. Even the jack in it won't raise it back up, so I'm thing the cylinder needs rebuilt. It's not a welded cylinder, so may see if I can get it out of there and take it apart.
  • Mark 149 J. said thank you
#9 Alc OFFLINE
  • 6,431 Thanks
  • 7,236 posts
Posted June 27, 2017 - 05:49 AM
Maybe a solenoid not working or a check valve stuck ? Any chance you have a service manual for it with some kind of electric / hydraulic schematic ?
#10 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted June 27, 2017 - 06:14 AM
No manual or anything. I tried finding something when I first got it working, but nothing was found.
#11 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted June 27, 2017 - 11:00 AM
I think you are right, Al! I pulled the one in the side of the pump and I think it is not working. It's a Deltrol 10033-21. Gonna Google that and see what I find.
#12 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,682 Thanks
  • 998 posts
Posted June 27, 2017 - 11:12 AM
That's the Kenny that I know!  Never give up!
#13 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted June 27, 2017 - 12:12 PM
We are back in business, sorta! It lifts, but won't go down. Pump does not run when I hit the down button. What I did was take the center part of the solenoid into the vise and put a little brake cleaner down into the plunger and tapped lightly with a punch and hammer. Now the plunger works again. I going to investigate the wiring, I think someone has changed things around as I see no direct 12V to the switches. Pics to come!
I can let it down right now by opening the valve on the manual jack for it.
  • Oldford and Mark 149 J. have said thanks
#14 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted June 27, 2017 - 01:04 PM
I worked up a diagram of how it is wired right now.
Seems odd but it raises it. Just haven't figured out how to let it down with the button. Seems the solenoid is not working, but unsure. Bmerf posted this in to original thread as a way to wire it.
Not sure if this would work here!
#15 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted June 27, 2017 - 09:36 PM
I think you're missing 12v to the red wire.
Can you post a pic of the small solenoid and what it's mounted to?
