Flat Tires
22 replies to this topic
#16 Cvans ONLINE
  • 6,648 Thanks
  • 6,129 posts
Posted June 25, 2017 - 11:42 PM
Looks like a good product. Unfortunately for us up north it is only good to -10 degs.   :wallbanging:
#17 Greasy6020 ONLINE
Greasy6020
  • 1,477 Thanks
  • 1,399 posts
Posted June 25, 2017 - 11:43 PM
We talking -10 metric or imperial?
#18 Alc OFFLINE
  • 6,885 Thanks
  • 7,461 posts
Posted June 26, 2017 - 05:31 AM
Will those thorny things be a standard mowing problem ?  That's worse then driving in a construction site !
  • Cvans said thank you
#19 Cvans ONLINE
  • 6,648 Thanks
  • 6,129 posts
Posted June 26, 2017 - 08:13 AM
This is from their site.
TireJect is Freezeproof down to -10F
Edited by Cvans, June 26, 2017 - 08:13 AM.
#20 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted June 26, 2017 - 11:20 AM
Foam filled tires will ride a little stiff but will ensure you never have to worry about this issue again. If you are going to be mowing this area regularly then it's the way I would go. If you go the plug route then you may and up with tires that are more plug then rubber over long term and the thought of plugging tires everytime I mow just make my head want to explode.
  • Cvans and MolonLabe have said thanks
#21 Bob E OFFLINE
Bob E
  • 126 Thanks
  • 101 posts
Posted June 26, 2017 - 06:54 PM
I don't have any kind of thorns to deal with, but I have old tires full of plugs from the previous owner's, side wall cracks, and a cracked valve stem on one. Liquid Laundry Starch keeps them full of air. It works like slime, but a lot cheaper. I've mixed anti-freeze with it to keep it from freezing in the winter. It works great. I had to put some air in my tires this spring. I checked them again the other week when it was in the 90's and I had to air them down. :D
  • MH81 and Cvans have said thanks
#22 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,004 Thanks
  • 4,414 posts
Posted June 26, 2017 - 07:15 PM
To the extremes. http://otrwheel.com/...fing-tireliner/
#23 4tom OFFLINE
4tom
  • 155 Thanks
  • 166 posts
Posted July 11, 2017 - 06:44 PM
I'm thinking of fix a flat foam to fix existing leaks, and a tube full of washer fluid for traction. I know the foam sucks when you change the tire.
